12th Apr 2021, 2:11 pm | #61 |
Re: Reps JC20 Reel to Reel
I'm not quite sure where this long and detailed Thread is going?
As far back as Post#42, the OP has clearly stated that he does not wish to use his equpment for music reproduction - they are just for Show only. And here we all are suggesting circuit tweaks...
Edward. |
12th Apr 2021, 4:36 pm | #62 |
I have taken it in today for a full check over and to fit all new capacitors. I'll post back when it's all done.
Thanks all for your help. Les |
18th Apr 2021, 8:36 pm | #63 |
I like to say thanks to the man for doing this work for me I do a full post later as I still have lots of work to do .
Les |
19th Apr 2021, 7:05 pm | #64 |
After the electrics were done I now realise I have mechanical problems.
The 2 white and 2 black drive wheels are much smaller than the originals. I played a tape which sounds like Mickey Mouse and the nearest settings were 3 3/4. I recorded it onto the computer, made adjustments until the speech became clear and it's running 0.562 out. My plan now is to take the 2 aluminium take-up pulleys which the rubbers run on, measure all the sizes, lathe new pulleys and add the 0.562 which should bring everything back into spec. Long way going about it but don't think these rubbers will be obtainable anymore. Just to add the man who did the electrics said the amplifier and the volume is outstanding quality and he was quite happy playing his radio through it. |
20th Apr 2021, 8:00 am | #65 |
Before going to all that bother, (which sounds counter-productive to me - apologies) can you try a selection of other tapes? I'd send you a studio-quality 7.5ips tape foc but I can't get to the post at the mo.
Graham
Half my stuff is junk - trouble is, I don't know which half! |
20th Apr 2021, 8:06 am | #66 |
20th Apr 2021, 5:45 pm | #67 | |
and work out RPM on the same tape is 65 so if you add the RPM that will help a lot Thanks Les |
20th Apr 2021, 5:58 pm | #68 |
at 3 3/4 it play ok forwards and backwards------ on fast only work one way--- If I set it to15 fast forwards and back ok so its pushing the rubbers out more adding weight to the take up spools.
21st Apr 2021, 8:38 pm | #69 |
I tried an experiment today. I glued a piece of rubber band to the pulley refitted it to the left side as there was no drive in reverse. This greatly improved the drive and I had to take all the weight off to get it to move as it was really too big. The join in the elastic band makes the tape jump on rotation and it lost all drive on fast forward. Repeating my earlier experiment it was running at 65rpm now it is running at 74rpm to sound the same. I have removed the elastic band but my theory on rubber shrinking or wearing down seems to be correct.
25th Apr 2021, 8:01 pm | #70 |
I have got there in the end after taking 3 days off, the problem was the counter pully belt mods can close this post as it all done .
25th Apr 2021, 8:33 pm | #71 |
IF the tape that come with it was last used in 1973
26th Apr 2021, 1:58 pm | #72 | |
