29th Mar 2021, 4:03 pm | #1 |
HMV Reel to Reel Tape Deck 2210 (actually 2208)
Hi
Have just come into possesion of a HMV Reel to Reel Tape Deck 2210, juyst cleaning it , it does work albeit low vollume ( But the tape may be crap) noticed a Cap with one of its lead come away, ook it out, not sure if it is worth trying to resolder a lead back onto it, it is bulging out a bit at the bottom ( or it could be the rubber perishing or whatever it is that is sealing it with ). So the question is what will be a modern equivelent if any to this Cap . Make: CCL 4540uf - 35v dc. WKG.vF58/$ H6 . PS: Have charged it with a diode test and it holds about 0.9v and slowly comes downwhen tested with DC meter ! . Spike |
29th Mar 2021, 4:07 pm | #2 |
Re: HMV Reel to Reel Tape Deck 2210
That is a 450uF 35V electrolytic capacitor. The nearest modern value is 470uF. Any replacement should be rated at 35V or higher.
29th Mar 2021, 4:14 pm | #3 | ||
Spike Quote:
Spike |
29th Mar 2021, 5:50 pm | #4 |
Fit the new Cap, now it doesn't work at all, it worked with the old Cap with a terminal not connected, but not after puting a new Cap in, did not hear anything blown, is there an on board fuse on these machines, had a look and I can't see anything obvious.
cheers Spike Last edited by Spike47; 29th Mar 2021 at 5:56 pm. |
29th Mar 2021, 8:41 pm | #5 |
Now working ok with new Cap, forgot to put the Voltage selector back in !
29th Mar 2021, 9:10 pm | #6 |
Mods - the model number is actually 2208 (according to the OP's photo), not 2210 - perhaps a change to the thread title?
The two 450uF capacitors are in the two solenoid circuits (remote pause and end-of-tape stop foil contact). The HMV 2208 uses the Thorn DC43 tape deck (mechanical part) and is a three speed, four track model. Unless it has been serviced recently, you may well find that the rubber idler wheel that transmits the motor pulley drive to the capstan flywheel, doesn't move freely, due to hardened grease in its swivel arm bearing. |
29th Mar 2021, 10:39 pm | #7 |
Re: HMV Reel to Reel Tape Deck 2210 (actually 2208)
I personally would have fitted a capacitor with a much lower working voltage, say 35 or 50V
29th Mar 2021, 11:07 pm | #8 |
If the OP has the 200V capacitor to hand, it won't do any harm.
30th Mar 2021, 8:09 am | #9 |
30th Mar 2021, 8:45 am | #10 |
If it hasn't already been replaced with a modern component, I recommend you replace the "Hunts" (the manufacturer) 0.003uF 300Vac capacitor connected across the audio output transformer's primary winding - as per the photo. If the original type is still fitted (it might be a brown colour, but with the same markings), it will almost certainly have become more of a resistor.
9th Apr 2021, 5:12 pm | #11 | |
Sorry for late reply, I work away. Thanks for your reply, it all seems to work mechanical fine, have give it all a blow off and a clean and applied some silicone grease where needed . Only problem I can ( Hear) is the vollume is quite low, now I don't know if the old tape is much good !. Cheers Spike cheers Spike Last edited by Spike47; 9th Apr 2021 at 5:17 pm. |
9th Apr 2021, 5:14 pm | #12 | |
Thanks for that, sorry for late reply, the sound is not very good , would that have an effect on that ?. cheers Spike |
9th Apr 2021, 5:24 pm | #13 | ||
Other possible causes: Tape is the wrong way round (i.e. the magnetic coating side is not facing the record/playback head). The felt pressure pad that should hold the tape pressed against the record/playback head is missing. There could be another fault in the electronics. If you remove the cover over the heads/pinchroller, you’ll see two screened leads going to the record/play head. Select playback and pause. With volume at maximum, you should hear a loud hum/buzz if you touch the inner wire (i.e. not the outer screen/braid). Depending upon which track you select, this will be either the top connection or the lower one - try both tracks. |
9th Apr 2021, 6:16 pm | #14 | |||
9th Apr 2021, 6:34 pm | #15 |
Would this do .0.0033uF 500V Hunts Capacitors 3.3nF Axial Vintage0.0033uF
9th Apr 2021, 6:40 pm | #16 |
Is it non-Polorised ?
9th Apr 2021, 6:48 pm | #17 |
or this :3.3nf 0.0033uF 0.0033µF 5% 630v axial metallized poly capacitor cap .
9th Apr 2021, 6:52 pm | #18 |
Or this : Epcos Capacitor, Y2, 3.3Nf, 300V
9th Apr 2021, 7:11 pm | #19 |
Here is some more pics of the HMV 2208
9th Apr 2021, 7:36 pm | #20 |
