15th Feb 2021, 5:46 pm | #1 |
Surprise in wall wart.
I needed a "plug" to stick on a box and found an old big plug DC adaptor with switched variable output. To my surprise it had a multi tapped transformer, bridge rectifier and smoothing cap., no regulation..
15th Feb 2021, 6:48 pm | #2 |
Re: Surprise in wall wart.
I recall that Maplin offered this kind of thing till quite late in the day, I'm sure there's one in the wall-wart box somewhere. Presumably, a lowest-bid item from a Chinese supplier until the day that x amount of iron and copper finally cost more than a bit of iron dust core, less copper and a few semiconductors!
15th Feb 2021, 7:14 pm | #3 |
Presumably it cost a few pence less to do it that way than use a LM317 plus a few resistors.
15th Feb 2021, 7:14 pm | #4 |
The type of wall wart described was the norm until switched mode technology became affordable.
The output voltage was not normally regulated and care had to be taken not to over volt the items powered thus. The nominal "6 volt" setting was about 8 or 9 volts at low load and ideal for use in place of a small 9 volt battery. |
15th Feb 2021, 7:39 pm | #5 |
I've got - somewhere - an "Eagle" brand wall-wart from the late-60s that has a little switch on the front offering 4.5/6/7.5/9/12V outputs.
Never investigated it deeply. I guess the switch changed secondary-taps. It worked just fine to power a Philips "monoknob' cassette-recorder [which would otherwise have needed five C-cells] when recording Top-of-the-Pops. |
16th Feb 2021, 4:44 pm | #6 |
Some of the wall-wart and similar power supplies with voltage regulation had a 2-pole voltage selector switch. One side switched resistors to the voltage regulator chip (often an LM317), the other side switched taps on the transformer secondary. I guess that reduced the heat disipated in the regulator.
16th Feb 2021, 6:15 pm | #7 | |
I usually look though the AC adaptors at the charity shops and it's amazing what is available. Many intended for cell phone chargers can be used for other applications. Dave, USradcoll1 |
17th Feb 2021, 4:41 am | #8 |
These were quite common in the 1980's, with many made by Altai (even if re-branded as another make).
There probably wasn't much room inside the case (and were usually fully-sealed so difficult to cool the insides) to have a fully-heatsinked regulator at a few hundred mA's so could be a fair power-dissipation as Low-dropout ones were also much-rarer then Plus the switch would have to be more complicated to switch regulator's feedback / output voltage and also the transformer's secondary to minimise output voltage / drop across regulator to keep efficiency a bit higher. Although the cheap transformer in many of these ran hot with no load, and often the > +105degC thermal fuse in these failed. Even most 'fixed-voltage' equipment PSU's were unregulated - like Sinclair computer '9V' ones, that were much-higher at less than 1A etc. load. So you could get a 'pre-regulator to put inline with the computer to regulate the voltage down much lower to minimise heat inside the computer. Power-efficiency regulations and desire to minimise weight & size has probably eliminated linear-PsU's (even regulated ones), with Switch-modes now the norm. Although you could always add a small DC-DC step-down converter module on the output of an unregulated transformer DC-rectified / smoothed adaptor. |
17th Feb 2021, 7:35 pm | #9 |
The version of the Maplin multivolt adaptor I had failed because of an open transformer primary winding. It did have an LM317 regulator inside it and was free from any RF spoiling my radio reception. I have the newer Maplin multivolt version too, but it is a switched mode supply and no good for AM radio circuits.
17th Feb 2021, 9:19 pm | #10 |
Evening All,
This reminds me I have one which I have just dug out, as you can see it's badged Dixons. It weighs 9oz, a transformer I suspect and multi-voltage. The brightness of the output indicator LED depends on the volts selected, it's smoothed but unregulated. Note the plug/socket in the cable to reverse the polarity!
Andrew Illegitimi non carborundum Last edited by MeerKat; 17th Feb 2021 at 9:20 pm. Reason: add white space |
18th Feb 2021, 12:23 pm | #11 | |
The LM317 has a nearly 3V dropout voltage - And could be more across it if they didn't switch input voltage. So probably couldn't get anywhere near its max 1.5A current, without it overheating. Although the transformer in these probably limited current to < 0.5A (especially with a regulator to get hot) Last edited by ortek_service; 18th Feb 2021 at 12:32 pm. |
18th Feb 2021, 12:29 pm | #12 | |
Many, as well as o/p voltage (transformer tapping / possibly regulator feedback amount) switch, also had a polarity-switch. Once I'd set these correctly, I often put tape over these, to stop these accidentally getting knocked and possibly damaging equipment being powered - It was quite common back then for these not to be reverse-polarity protected never mind any over-voltage shut-off. |
18th Feb 2021, 9:41 pm | #13 | |
[QUOTE=ortek_service;1343295]
Thank you. This solution was also suggested by other forum members when I posted in relation to my failed wall wart in a previous post. However, I was unable to locate the fuse. Please see photos of the wall wart innards. I have thrown away the transformer, but have kept the PCB sans the LM317T, which I have used to build another regulated power supply. My new PSU goes from 0 to approximately 9V continuous and can be smoothly adjusted via a 5K pot. |
18th Feb 2021, 10:18 pm | #14 |
19th Feb 2021, 4:07 am | #15 | |
They also did many 'CB' power-supplies, that were identical apart from the front label. And quite a few were Altai-branded, as well as other names. Altai certainly seemed to be the original manufacturer behind a lot of Multimeters, where there were a lot of identical looking different-brands (with actual Altai brand less common, but may have also used Eagle etc.), so were most-likely made in the same factory. |
19th Feb 2021, 4:19 am | #16 | ||
[QUOTE=Jolly 7;1343500]
I presume it wasn't found on the other side either (May have to cut plastic insulating sheet away) - As sometimes they brought the long lead of fuse around to the other side, to give more strain relief / thermal soldering protection. It might be they omitted it, for cheapness / early ones didn't have this, and was a later addition for added-safety. There was often a symbol on the PSU's label, with the temperature rating of the thermal fuse - which despite being usually over 100degC, would rather worryingly often fail so wondering if the transformer really got that hot! |
19th Feb 2021, 12:19 pm | #17 |
100C isn't necessarily that hot for a transformer, depending on the insulation materials used. The 100C trip probably relates to the other components in the unit and the touch temperature of the plastic case.
If the (cheap) unit is only designed for normal room temperature operation- up 25C, say, there could easily be problems running it hard in a confined space or direct sunlight.
19th Feb 2021, 3:41 pm | #18 |
Something I've always done, and highly recommend, is checking the output(s) of all wall warts before using them for the first time; whether supplied on their own or with a piece of equipment.
In the early 90's I built a NICAM TV tuner/decoder unit purchased in kit form, from Maplin and quite expensive at the time. I spent a weeks worth of evenings populating the (five ?) circuit boards and doing all the wiring. Fortunately, I checked the 12V PSU Maplin had supplied with the kit, only to find it was giving out twenty plus volts. Internal investigation revealed a 7812 regulator and heatsink, literally broken in half! It must have been rammed in the case with some force and later snapped. Externally, the PSU looked perfect. I let Maplins know my concerns about this in no uncertain terms! Happily, the decoder worked fine but it was a good job I checked. Jerry |
20th Feb 2021, 12:15 pm | #19 | |
Especially as I think some of the thermal fuses used were >120degC, when they did start using these. I have noticed that the cheap ones often got quite hot, even with no load. And had read that some may have been designed for 60Hz, and running them at 50Hz meant the cores weren't large enough for the power (Maybe similar with some ones in certain (FKI etc) CB PSU's used to buzz quite loudly). Whereas, if you bought a replacement transformer from a UK distributor like Maplin back in the 1980's, these would run completely cool. |
20th Feb 2021, 12:57 pm | #20 |
Large power transformers may approach 100% but the cheap wall wart variety are more likely to be around 85%. Depending on where the cheese paring has gone in the design, they may well run almost as hot on no load as on full load.
Insulation temperature ratings range from Class A at 105C to Class H at 220C.
