Old 1st Apr 2020, 10:50 am   #1
saddlestone-man
Default Vauxhall Type VR Car Radio
Hello All
I wonder if anyone knows who made radios for Vauxhall, specifically the Type VR as fitted to the Velox and Wyvern models of 1950?
best regards ... Stef
saddlestone-man is offline
Old 1st Apr 2020, 11:24 am   #2
HamishBoxer
HamishBoxer's Avatar
Default Re: Vauxhall Type VR Car Radio
I wonder if Pye or Radiomobile. Might be worth if no definitive answer trying to find a picture of interior of said car.
HamishBoxer is online now
Old 1st Apr 2020, 11:54 am   #3
AC/HL
AC/HL's Avatar
Delco?: https://www.google.com/search?q=vint...nt=firefox-b-d
AC/HL is offline
Old 1st Apr 2020, 6:40 pm   #4
saddlestone-man
There's a description and schematic of the radio in Radiophile for Spring 2007, but no maker indicated.
The valve line-up is:
EF39 RF amp
ECH35 frequency changer
EF39 IF amp
ECH35 detector, AVC rectifier, AF amp and phase splitter
2-off EL32 push-pull audio output
0Z4 rectifier
Does this look like any other radio someone might be familiar with?
Old 1st Apr 2020, 7:44 pm   #5
Ed_Dinning
Hi, I fixed one of these very many years ago that had a burnt out inverter transformer.
About 5 push buttons for four MW and LW stations as well as variable tuning.
It was a really good set, but no idea who made it
Ed
Ed_Dinning is online now
Old 2nd Apr 2020, 7:43 am   #6
toshiba tony
toshiba tony's Avatar
Push pull valves on a car radio, they didn't hold back, did they? When did B9A valves appear?
toshiba tony is offline
Old 2nd Apr 2020, 9:04 am   #7
barrymagrec
Not Radiomobile - they used B7G valves at this time - push pull N78s on some models though.
barrymagrec is online now
Old 2nd Apr 2020, 9:50 am   #8
toshiba tony
I'd forgotten about that valve base type, were they the ones with the location pip at the bottom, same as a ul41?
Old 2nd Apr 2020, 9:53 am   #9
toshiba tony
Sorry, should have looked, same as an EL91/95, 7 pin.
Old 2nd Apr 2020, 10:17 am   #10
Herald1360
Herald1360's Avatar
A short aerial and a noisy operating environment would suggest that an RF stage and a high power output were desirable. Early car radios were also definitely luxury offerings. The bean counters got there eventually.....
Around 1948.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 2nd Apr 2020, 11:12 am   #11
Boulevardier
Hang on...this thing's a car radio. Seven octal valves? How big was it? Did it occupy the front passenger seat?
Mike
Boulevardier is online now
Old 2nd Apr 2020, 11:24 am   #12
G6Tanuki
G6Tanuki's Avatar
Not sure about this particular one, but in the 40s/50s it was normal for car radios to be in two separate units: the 'front-end' in a small dashboard-mounted unit and the power-supply/audio-amp stages in a bigger box which lived under a front seat or was sometimes mounted in the engine-compartment (this latter approach also avoided intrusive vibrator-hum).
A RF amp was very much needed with some early car-'aerial' setups - such as a wire run along the _underside_ of one of the running-boards or built into the fabric-covering to the roof.
G6Tanuki is offline
Old 2nd Apr 2020, 11:28 am   #13
turretslug
turretslug's Avatar
I've even heard it said (not sure how prevalent it actually was) that some people went as far as fitting surplus radio compasses to cars, with the receiver unit in the boot and control unit up front with simplified aerial and adapted PSU arrangements!
I have to admit that my initial reaction was the same as Mike (Boulevardier)!- How big?
turretslug is offline
Old 2nd Apr 2020, 11:56 am   #14
Boulevardier
Yes, I've come across a few of those split radios. Even so, the thought of getting three octal valves, associated RF/IF transformers, a (presumably) three-gang tuning capacitor (or permeability tuner), and a five-way pre-set unit into a "small dashboard-mounted unit" is pretty mind boggling! Pictures of this beast would be interesting...
Mike
Old 2nd Apr 2020, 4:48 pm   #15
toshiba tony
It's come back to me now, only a few years ago someone gave me one, the audio output and the vibrator psu was in one case and tuner head was in the case that sat on the dash. Whether it was TRF or IF I can't remember but I do recall that one of the valves had an anode voltage of 12, All cars in those days were positive earth, but they had a slide switch to allow it to be used in negative earth cars.
Old 2nd Apr 2020, 8:05 pm   #16
AC/HL
AC/HL's Avatar
The "small dashboard mounted unit" needn't contain much. The tuning control was sometimes via a Bowden cable, with everything else hidden elsewhere. Radios only became common with the advent of miniature valves.
AC/HL is offline
Old 2nd Apr 2020, 8:19 pm   #17
Ed_Dinning
The one I worked on was pretty big and formed the centre section of the dash and had the flying V logo on the front of the case. all in a nice screened box and the PSU bolted to the back.
Any chance of a pic?
Ed
Old 2nd Apr 2020, 8:28 pm   #18
Heatercathodeshort
Heatercathodeshort's Avatar
I believe Ekco manufactured the type that fitted behind the dash board with pre set roller controls protruding through. My mate one had one in a Velox. It sounded very good and picked up Radio Luxembourg loud and clear. John.
PS RF amp, Frequency changer, I.F and detector [3] audio driver, 2 X output pentodes and HT rectifier. [4] That makes 7 in all.
Heatercathodeshort is offline
Old 2nd Apr 2020, 8:28 pm   #19
Boulevardier
Ah, Bowden cables. I hadn't thought of that. This must have made such a radio a very expensive accessory to fit to a car, and presumably factory fitted.
Mike
Old 2nd Apr 2020, 8:38 pm   #20
Boulevardier
John and Ed - I'm still bemused by the idea of how big a unit with 6 octals, etc must have been, wherever it was positioned and however you configured it all. Pictures would indeed be interesting.
Mike
