Old 16th Apr 2019, 12:36 pm   #1
Gi4CZW Cliff
Default SWR using twin feeder and bulbs ?
Just heard that in older days SWR indication of forward and reverse power of a 'ham radio transmitter could be shown, using a length of twin feeder and two torch bulbs. My older books fail to show this device and so I'm not sure, if the twin line has to be terminated, or how the distinction between forward and reverse is effected. Mr goggle not finding it for me. Your thoughts appreciated. Cliff.
Gi4CZW Cliff is offline
Old 16th Apr 2019, 12:57 pm   #2
ms660
ms660's Avatar
Default Re: SWR using twin feeder and bulbs ?
http://www.rfcafe.com/references/qst...tober-1947.htm
Any use?
Lawrence.
ms660 is offline
Old 16th Apr 2019, 1:01 pm   #3
G8HQP Dave
SWR (standing wave ratio) tells you about peaks and troughs of voltage or current on the line. Anything which can sense voltage or current can thus be used to detect standing waves. A rough estimate of SWR may then be possible. A properly terminated line will have SWR 1:1 so nothing much to see.
G8HQP Dave is offline
Old 16th Apr 2019, 4:00 pm   #4
G6Tanuki
G6Tanuki's Avatar
Part of me wonders if you were to try building such a thing these days whether a pair of modern 'high output' LEDs might not be a better, more sensitive indicator than old-fashioned incandescent bulbs?
I've got a homebrew 'Wheatstone Bridge' SWR-indicator here which uses a blue LED as its null indicator, and it works just fine with half a Watt of RF.
G6Tanuki is offline
Old 16th Apr 2019, 4:23 pm   #5
lesmw0sec
You can either have a short or an open circuit at the end of the line. What you are trying to achieve is a high SWR. An rf indicator of some sort (a bulb if the power is high enough) will reveal peaks and nulls of energy at wavelenth intervals along the line. While this is practical for VHF and above, you can visualise the length of feeder required to measure 40 M plus!
lesmw0sec is offline
Old 16th Apr 2019, 4:37 pm   #6
trh01uk
trh01uk's Avatar
I was also told by a WWII veteran engineer that it was a routine way to measure frequency in the days when frequency counters were yet to be invented. Just note the position of two peaks (or troughs) then take a ruler and measure the distance to get the wavelength. For open wire lines the velocity factor is near 1, so you can use the normal formula to then get frequency. He told me his lab had a pair of lines all set up ready to go with a bulb pickup - for him it worked well because he was using 50MHz or thereabouts so the wavelength fitted in the room!
Richard
trh01uk is offline
Old 16th Apr 2019, 5:05 pm   #7
dave walsh
An elderly Amateur, whose home I used to visit in the sixties, had a large Bungalow with Aerial's terminating on the roof and he used mainly open wire feeders moving a bulb along to "improve" the SWR re his [much modified] and prone to flashovers Heathkit DX100 Transmitter. He explained this was a pre-coax technique but I can't claim to be more knowledgeable than that. I recall that the wire he used wasn't that new or sophisticated at all-maybe fencing gauge [He lived next door to the Corporation Depot and Storage Yard so there could have been a connection]
Dave
dave walsh is offline
Old 16th Apr 2019, 5:10 pm   #8
G6Tanuki
G6Tanuki's Avatar
Richard
Yes, a "Lecher Line" https://en.wikipedia.org/wiki/Lecher_line
Works well up to UHF, as Randall & Boot discovered when they wanted to measure the frequency of their first Cavity Magnetron during WWII.
G6Tanuki is offline
Old 16th Apr 2019, 5:40 pm   #9
Gi4CZW Cliff
Well done Lawrence ms660. I put some twin-feeder, loop, led's, and a dummy-load together for fig2B and yes it works. I did find that my solid state Tx doesn't like high swr and folded back its power-out but I got just enough, I'm now ready for tomorrow's QSO. Many thanks. Cliff.
Old 16th Apr 2019, 5:46 pm   #10
Gi4CZW Cliff
Oops, I should have made clear that my TX folded back its power when I simulated high SWR to light the reverse power LED. Cliff.
Old 16th Apr 2019, 9:17 pm   #11
LeakyGrid
In the 1930s and 1940s, before and after the war, my uncle (G3QQ) had an aerial strung between a flag pole and a chimney. It was fed by an open-wire feeder made from wooden dowels and bare copper wire. I now believe this to have been a Zepp, which runs with a high SWR.
From time to time he would hang mains neon bulbs along the feeder, to check the standing wave pattern. I was about 6 or 7 at the time, and could only marvel without understanding.
Roger
LeakyGrid is offline
Old 17th Apr 2019, 11:11 am   #12
G8HQP Dave
The distance between peaks (or troughs) is half a wavelength. You also need to take account of velocity factor, but for an open wire feeder this will be near 1 anyway.
