10th Mar 2018, 8:09 pm | #1 |
Possible Phenomenon
Within my private enclave I use a Harman Kardon 560 as my main amp.
The other day I noticed that it was playing through one channel and my thoughts immediately were more associated with "Horror of Horrors". Could it be a loose connection or faulty component or just a wire that had come off somewhere or had the output protection device functioned? I then remembered that the better half had been polishing in and around the area so I checked all connections which were all sound. I decided to leave it until this morning after I had been for the paper and lottery tickets. Here is where the problem starts. The item is a USA model and as such I use a 110V supply and the original 2 pin USA plug on the amp lead. My first thought was to remove the txfr so that I could power the item in my work area (kitchen at this time). It was then that I noticed that the amp plug was half hanging out of the socket. Clearly, I pushed it fully in whereupon the other channel picked up immediately - strange or what? |
10th Mar 2018, 11:44 pm | #2 |
Re: Possible Phenomenon
clutching at straws, suggests half wave AC.
2 pin or 3 pin plug? Any other source of a possible earth/ground |
11th Mar 2018, 2:02 pm | #3 |
Hi Bookman,
I would start by checking the plug for signs of heating on its exterior Terminals. If present, it could signify lower power was getting through. Regards - Mike |
11th Mar 2018, 2:51 pm | #4 |
Clearly, if you're interested in investigating further, you could run the amp with something like a lamp limiter in what was the partially-disconnected leg and make some measurements and observations.
I do think things like this are worth following up; we too easily assume that current theory explains all that is worth knowing, and dismiss anything which seems not to fit, thereby perhaps missing some important discoveries. |
11th Mar 2018, 3:00 pm | #5 |
One side only getting its neutral connection via a short to earth?
11th Mar 2018, 3:08 pm | #6 |
... unless the supply is served by an RCD - in which case it would surely trip.
11th Mar 2018, 3:34 pm | #7 |
Phantom power?
11th Mar 2018, 3:41 pm | #8 |
30mA at mains voltage is a what? 'Leccy leaking from the plug, laa.
11th Mar 2018, 3:54 pm | #9 |
I can confirm that this is a 2 pin unearthed supply with no direct or indirect earth connected. The attached diagram does however show items bonded to the chassis with an earth symbol?
11th Mar 2018, 4:14 pm | #10 |
11th Mar 2018, 4:21 pm | #11 |
Does it have an anti-thump relay or other shutdown system?
I was just wondering if an arcing/resistive mains connection could have reduced the rail voltages and just hit the point where one channel shut off and the other one wasn't quite at shutoff due to tolerances? David
12th Mar 2018, 5:58 pm | #12 |
I was thinking maybe it shut down due to a sharp thump due to a poor connection. I had a radio cassette that did similar, one day the mains lead came loose causing a loud thump in the speakers then silence, so I reconnected the lead properly and switched on and all was well, similar to your experience yes? Not important my radio was Sanyo brand run from 240 volt mains
13th Mar 2018, 3:57 pm | #13 |
It sounds like a dry joint. Is the mains socket mounted on the main PCB, or does it touch the PCB?
Pushing the connector fully-in has disturbed something completely unrelated to the mains (maybe by flexing the chassis...if it has one). |
