1st Mar 2021, 8:56 pm | #1 |
EKCO K12 Battery Eliminator
Hi are any of you familiar with this model. I have purchased one. It only has 4 sockets in the paxolin on the top and a piece of that is broken. Not sure if It was a toggle switch hole or a hole for a flex. I know this model had a heater battery trickle charge which could be set at 2,4 or 6 volts
Alex |
1st Mar 2021, 9:18 pm | #2 |
Re: EKCO K12 Battery Eliminator
HimAlex, if you can post a picture it may jog memories as EKCO had a big range of battery eliminator types
Ed |
2nd Mar 2021, 3:35 pm | #3 |
Some information here: http://www.radiomuseum.co.uk/batelimin.html
These units normally trickle charged the accumulator when the radio was switched off, as hum was a problem otherwise. |
2nd Mar 2021, 4:01 pm | #4 |
spec sheet covering K12
