Old 27th Feb 2021, 11:18 pm   #21
AD360 Rob
AD360 Rob's Avatar
Default Re: Bush 82CL squealing
Without exception, every Hunts black (or brown) low value capacitor has been leaky to some degree even using a digital meter to check. Whilst the majority may not have an effect on the circuit with low voltages my philosophy is that they're not going to get better, only worse and like others, I'd rather not be taking a set apart again to replace what I could have done for a few pence the first time. Electrolytics I find are a mixed bag with even those horrible looking Plessey red & black still capable of being ok after all these years (although that type do fail more ofthen than others)
AD360 Rob is offline
Old 28th Feb 2021, 12:00 am   #22
Radio Scotland
Radio Scotland's Avatar
Yeah may as well i suppose, Another few caps isn't going to add much to the work load. Although i'm not sure what type of capacitors would be a good substitute for the hunts.
Jay.
Help!! I've been electrocuted by a glass thing that glows
Radio Scotland is offline
Old 28th Feb 2021, 10:39 am   #23
crackle
I have found the wax paper and mould-seal type caps hardly need replacing in these 9 volt circuits, the leakage is insignificant, due to the lower impedance circuits.
The radio looks so much more original with its old components.
Replace what is faulty. Unless you have a radio with one of those Mullard modules, you wont want to keep taking those out of circuit.
Mike
crackle is offline
Old 1st Mar 2021, 5:45 pm   #24
Radio Scotland
Mike
Cheers for your input crackle, But theres only three of them so may as well change them while i have the radio dismantled, One has already broke so chances are the other two will follow suit soon enough.
I'm only seeing six electrolytics in this radio, Where is the seventh hiding ?
Old 2nd Mar 2021, 11:38 pm   #25
jonnybear
jonnybear's Avatar
Probably hiding under the loudspeaker.
John
jonnybear is offline
Old 2nd Mar 2021, 11:46 pm   #26
Radio Scotland
John
I've seen that one john.
Jay
Old 3rd Mar 2021, 11:17 am   #27
jonnybear
jonnybear's Avatar
John
Jay
Have a look at this page may help, someone in the past may have snipped one out so you will have to double check the circuit.
http://www.richardsradios.co.uk/bushtr82c.html. no connection.
John
Old 3rd Mar 2021, 3:17 pm   #28
Radio Scotland
John
Jay
John
Cheers john but i can't enlarge those pics. So its hard to tell, Iv'e a feeling its right under my nose
[img]************************R0smX4Z4/IMAG0260.png[/img]
[img]************************J4XM5fXB/IMAG0261.jpg[/img]
Old 3rd Mar 2021, 4:10 pm   #29
ms660
ms660's Avatar
In your photo of chassis underside, the standoff pin that the 56k (R16) and the 8.2k (R13) are connected to is where the -ve end of C24 should be connected, the orange wire from that pin goes to IFT1 as expected but there's another un-insulated wire that is connected to the above mentioned standoff pin, where does that go to?
Lawrence.
ms660 is offline
Old 3rd Mar 2021, 4:31 pm   #30
Radio Scotland
Lawrence.
Not sure which un-insulated wire your referring to lawrence, Does it look like there is a cap missing ?
Old 3rd Mar 2021, 4:48 pm   #31
ms660
ms660's Avatar
The one that's connected to the 56K (R16) and the 8.2k (R15) and the orange wire that goes to IFT1 in your 2nd photo link.
Lawrence.
ms660 is offline
Old 3rd Mar 2021, 5:03 pm   #32
Radio Scotland
Far as i can tell it goes to what looks like a small capacitor
Old 3rd Mar 2021, 5:11 pm   #33
jonnybear
jonnybear's Avatar
Yes Laurence I was looking at that wire and wondered if it is the rivet of the a plessey capacitor?, if so where is the rest of it. there should be a 8uf to deck at that point.
John
Old 3rd Mar 2021, 8:35 pm   #34
Radio Scotland
[img]************************TYW8Lz8K/IMAG0267.jpg[/img]
Old 3rd Mar 2021, 11:37 pm   #35
jonnybear
jonnybear's Avatar
looking at your image 0267, the white looking object with 20 in red on it looks like it could be the electrolytic you are looking for, + to chassis - to junction of 56k and 8.2k 10uf 25v would be ok. another close up picture of that device would be nice.
John
Old 3rd Mar 2021, 11:43 pm   #36
Radio Scotland
John
Didn't realise they made electrolytics as small as that back then. Take it that'll be the AGC Cap ? I'll clean up the writing on it and take another pic tomorrow,
Cheers,
Jay.
Old 4th Mar 2021, 2:45 pm   #37
Radio Scotland
John
Best i could do
Old 4th Mar 2021, 5:02 pm   #38
jonnybear
jonnybear's Avatar
John
Best i could do
If the wire coming out of the other end of that device goes to chassis it must be the electrolytic in question,replace with 10uf,make sure + goes to chassis, would not worry replacing those brown square caps as they are probably good would replace the small black hunts paper capacitors though.
John
Old 4th Mar 2021, 5:07 pm   #39
Radio Scotland
John
Best i could do
John
Yeah the other end goes to the chassis, I'll be replacing the hunts anyway as they are cracked.
Jay.
Old 12th Mar 2021, 11:26 pm   #40
Radio Scotland
Could anybody tell me if it would be ok to replace the three hunts capacitors with ceramics ?
