3rd Nov 2019, 1:57 pm | #1 |
Repair of industrial open frame monitor
Yet another teleprinter related thread from me, but this relates to the 9" monitor that is attached to one that was working up till yesterday....
Symptoms All was working well, just receiving a page of weather information, when for no reason, and with no warning, the picture just shrank away to nothing. Tube heater is still lit (but probably powered from the 12v rail anyway.) I have taken the monitor out, and powered it up on the bench - Zero activity from the LOPT - have checked the drive transistor, tests as working (BU408) Have performed a "Ring Test" on the LOPT and it certainly appears to be ringing well. There is a TDA1170s that appears to be responsible for most of the heavy work in the monitor. Any ideas as to where I should be looking - as I say the line stage appears to be completely inoperative.
Engineers make things work and have spare bits when finished Last edited by Sean Williams; 3rd Nov 2019 at 2:06 pm. |
3rd Nov 2019, 3:16 pm | #2 |
Re: Repair of industrial open frame monitor
Pic of ring trace.
If I grab the LOPT and hold it tight, I can damp the oscillations, so I think it is ok.
3rd Nov 2019, 5:53 pm | #3 |
The TDA1170 is a vertical deflection IC (only) I think. It does not include the line oscillator.
Is there another IC in there? The TDA1180 was often used for the line oscillator, etc. Or it might be discrete components. Is the line drive transformer-coupled to the base of the BU408? I've had those drive transformers fail open-circuit (which obviously stops the line output stage from doing anything), they are not hard to rewind though. |
3rd Nov 2019, 6:05 pm | #4 |
No Longer a Member
So you have a likely good LOPT and good H output transistor but its not working.
Check the drive at the base of the transistor, this includes therefore testing the driver transformer and the IC/circuitry driving that. If the drive to the base is normal then check the power supply feed to the primary side of the Lopty, are there any open solder joins or fusible resistors. Generally the driver transformer has a ratio of about 10:1. If you do find an issue with it, and you attempt to rewind and replace it, be cautious of the winding polarity. It pays to be aware how that works, it is often glossed over in the textbooks. When the driver transistor conducts or switches ON, it switches OFF the horizontal output transistor for flyback and during this time energy is stored in the magnetic field of the driver transformer. When the driver transistor switches OFF, it is the stored energy in the driver transformer's field which switches on the the H output transistor. It sounds after a few simple tests you should be able to find the issue, most likely the H drive has gone missing and the transformers are ok. |
3rd Nov 2019, 6:30 pm | #5 |
Thanks both.
Steep learning curves on all this modern stuff! The description of the H output system makes a lot more sense now - I was surprised to find the output transistor conducting even though nothing was happening. More checking and testing to do. Should the drive circuit work with the LOPT and output transistor removed? I think it will be safer this way?
3rd Nov 2019, 8:35 pm | #6 |
Okay, I have checked the driver circuit - there appears to be no voltage getting to it. The oscillator coil is giving continuity through it, so I guess I need to look deeper.
As luck would have it there is no schematic available for the machine, and it is a double sided board
3rd Nov 2019, 9:38 pm | #7 |
Been having a look at some online schematics for similar monitors.
I am now wondering if this will actually fire up on the bench - it looks like the H sync line is needed to set the driver transistor going, or am I missing something here?
3rd Nov 2019, 11:02 pm | #8 | |
No Longer a Member
There are some computer VDU's (probably not this one but possible) that do not have their own H osc, they use the incoming H sync. Fortunately this is not common. IBM did it though in some early VDU's. |
4th Nov 2019, 6:14 am | #9 |
Yes, the IBM5151 (MDA monitor for the PC family) had no horizontal oscillator, it fed the HSync (more correctly called Horizontal Drive in the technical reference manuals) signal to the base of the line driver.
If the little monitor disussed here takes a composite input then it will have a horizontal oscillator. If it takes separate syncs and video (often on a 10 pin 0.156" pitch edge connector) then it may not. You may have to trace out the appropriate bit of the circuit to work out what is going on. |
4th Nov 2019, 2:46 pm | #10 |
Have a look at the base of the driver transformer and see where it comes from. If it's from an IC, it's likely the oscillator is in it.
Your clue is that there's no voltage getting to the driver - there should be HT. Two ways this can be achieved. One is a permanent feed from the PSU - possibly 12v, though it may be higher. The second is to feed a kick from the PSU to get things going which is then taken over by a rectified winding from the LOPT with an isolation diode in the PSU feed. As this is a small screen unit I'd suspect the former method. Put a meter on the primary of the oscillator transformer and switch on - you may see a kick. Of course this all assumes the driver transistor is OK. If it's short, then the feed resistor will take the current, but might not appear distressed. |
5th Nov 2019, 8:35 am | #11 |
I've hooked the drive transistor out and tested it - it's an NPN device, and has some gain, so I think all is well with it.
If I get time this evening I will continue trying to trace (and draw) what is there - I'm getting lost continually flipping the board from one side to the other trying to follow traces.
5th Nov 2019, 11:16 am | #12 |
I'd leave the transistor out and see if a voltage magically appears at the collector pin. It could be the lack of a sync signal is turning the transistor hard on.
I'd disconnect the line output transistor's collector feed while fault finding in case things spring to life unexpectedly. |
5th Nov 2019, 10:23 pm | #13 |
what sort of connector does it use? Have you got a pic of the thing?
Kevin |
5th Nov 2019, 10:28 pm | #14 |
Its got a 10 pin DIL connector - I could get a pic - have closed up for the night.
The equipment is a German/English project, and manufactured by ITT Creed, or ITT Lorenz. Water is somewhat muddied by the Italian CRT Ive had a closer look at the drive transistor circuit - If my tracing is correct the base if the driver transistor is R/C coupled to the output pin of an NE556 - this makes me thing the H Oscillator is on board, and it just gets sync pulses from the video card - please correct my shoddy understanding if I am wrong. I will put a pic up later this week - Work is going to get in the way again now
5th Nov 2019, 11:04 pm | #15 | |
Chris
5th Nov 2019, 11:13 pm | #16 |
Hmm, this does rather complicate bench testing Gonna need a bigger bench - the machine it lives in isn't exactly small.
However, this might explain the almost complete "deadness" of the unit when only shown 12volts. Okay, will rearrange the workshop to allow for the TP to supply everything. Thanks All, this is just too modern for me.
6th Nov 2019, 6:12 am | #17 |
One thing to quickly check is if the halves of that 556 are used in conventional monostable or astable circuits.
A monostable has discharge linked to threshold. An astable has threshold and trigger linked. If you have an astable section it is likely that is the line oscillator here. Two monostables could be cross-connected as an oscillator, but I think that is unlikely. |
9th Nov 2019, 8:12 pm | #18 |
I have managed to get the monitor (and rest of the machine) on to the desk.
With H and V syncs the board is a lot more lively (Yes I know, several of you have pointed this out) The drive circuit is certainly switching well, there is a feeble, and I mean feeble spark of EHT. Second picture is off the driver transformer, First is the drive to the base of the line transistor. Wondering if it could just be a failed Boost cap (or tuning cap)
11th Nov 2019, 2:12 am | #19 |
No Longer a Member
Gulp ! Did you attempt to short out the EHT or get it to jump across a gap to ground ? Not a great idea in a semiconductor based monitor/TV. It can destroy or risk destroying the EHT rectifier that is integral to the LOPY (usually). Still, even if this does fail & short or go leaky the problem can be rectified (no pun intended) by adding a series diode. If it goes open is game over for the Lopty assembly.
The drive looks ok. You need to scope the collector of the line output transistor now. The peak voltage there varies, it depends on the monitor size and other factors, likely its under 400V peak, so "probably" a x10 scope probe will be ok, but if you have a x100 probe handy use that. (This voltage though in color sets can be over 1kV, but in a 9" to 12" monochrome monitor its around a two hundred to 300 volts peak, or thereabouts) Assuming the LOPTY is ok, there might be something loading one of its auxiliary windings, shorted diode, or capacitor. The form of the collector voltage will give the game away as to where the problem is and also indicate if the output transistor's collector voltage is doing what it should with the normal drive voltage a its its B-E junction. The tuning capacitor on the primary might also be faulty. Unlikely the energy recovery diode shorted, as that shorts the supply across the Lopty's primary, if that goes open, it likely destroys the HOT because the collector voltage goes very negative with respect to its emitter voltage. Generally these sorts of monitors do not have a "boost capacitor" as such. When the energy recovery diode conducts, magnetic energy of the yoke and output transformer is returned to the power supply directly and the damped current scans the left side of the raster. In valve sets the recovered energy charges a boost capacitor. In transistor sets though there are often a few lopty secondary windings with rectifiers to get negative and positive voltages to run things like the CRT's electrodes and the video output amplifier. Last edited by Argus25; 11th Nov 2019 at 2:23 am. |
11th Nov 2019, 1:40 pm | #20 |
As usual, Argus has given a detailed explanation of how it all works. A couple of things. Does the line output transistor get hot? If not, then it's more likely an open circuit somewhere, and the favourite point on a small monitor is the high-value non-polarised coupling capacitor to the scan coils. If it does get hot, then it's an overload, possibly a secondary derived supply or the LOPT itself.
