7th Mar 2021, 1:06 am | #1 |
Help with wires on PYE VHF 2D tuning cap.
Can’t find out where this brown wire on the left hand side. Can anyone help?
Working on a Murphy U198M, Marconi CR100, PYE VHF2D x2, P75A and 25C. |
7th Mar 2021, 1:07 am | #2 |
Re: Help with wires on PYE vhf 2d tuning cap.
As in where it is supposed to go to, cannot find any other brown coloured wires.
7th Mar 2021, 11:09 am | #3 |
As we cannot see either end, that picture doesn't help!
Where is the attached end attached too? What does the circuit diagram show?
Regards, Ken. BVWS member |
7th Mar 2021, 12:36 pm | #4 |
Re: Help with wires on PYE VHF 2D tuning cap.
If we're to tell you where the wire goes to we'll need to know where is comes from.
The service sheet is your friend.
7th Mar 2021, 5:30 pm | #5 |
Yes I have the service sheet but can’t figure it out.
It comes from tuning cap, valve end, and I can’t find any other brown wire nearby that would have been cut. Also what I’d the wiring layout on the blue wires at the gang side.
7th Mar 2021, 5:43 pm | #6 |
The tuning capacitor is made up of two ganged sections. C3 is the Radio Frequency (RF) section and C18 is the Local Oscillator (LO) section.
As far as I can see both sections are connected to various points on the wave change switch. The RF section is also connected to L1 primary, C5 and C66. I can't see any connection to a "valve end". Component references are to manufacturer's service sheet.
7th Mar 2021, 6:00 pm | #7 |
The tuning cap is a two-gang 528pf/528pf, being C23 and C35.
C23 goes to switch S5w and S6x then on to C24, 100pf in section G4 of Trader sheet 1410. C35 goes to C34, 100pf also in section G4. Have you removed C24 and C34? Have you replaced them? Please take a good, well lit, picture of the underside of the chassis in the area G4. We also need to know which service sheets you are using as they are numbered differently.
Regards, Ken. BVWS member Last edited by Kentode; 7th Mar 2021 at 6:03 pm. Reason: Post crossed. |
