7th Mar 2021, 5:44 pm | #81 | |
Re: OFCOM re: International Commission on Non-Ionizing Radiation Protection (ICNIRP)
There is no good answer to that. If a government believes in the ICNIRP limits then how can it allow them to be flaunted by inconsistent regulations? The new rules are not an attack on amateur radio specifically, they have a much wider remit. The 10W EIRP (that's not PEP or 10W from the transmitter) is the quick fudge to take mobile phones, smart meters, Wifi, Bluetooth and hand-held radios out of it (for the moment). |
7th Mar 2021, 5:58 pm | #82 | ||
Either on a belt, or any item of clothing it can be attached too, generally the trousers. Or on a guitar strap is another common placement. Naturally the location of the transmit aerial will vary, most exit on the top and are rigid although the ones for VHF systems are generally a longer wire aerial and as such will generally flop down. |
7th Mar 2021, 6:53 pm | #83 | |
We were given an extra MHz at 2 Metres a few years back.... |
7th Mar 2021, 9:28 pm | #84 | |
7th Mar 2021, 10:31 pm | #85 | |
If you actually want to read yours trying looking in your junk folder, it may be there. |
7th Mar 2021, 10:35 pm | #86 |
From the date at which the licence is varied to include EMF existing users have 6 months
to comply for use above 10MHz, and 12 months below 10MHz - see 12.6 https://www.ofcom.org.uk/__data/asse...nforcement.pdf |
7th Mar 2021, 10:36 pm | #87 | |
For a long time now, it's been 10mW for a handheld, or 50mW for a body-worn pack. The higher power permitted for a pack is due to the aerial being so inefficient when very close to the user (effectively a bag of, mostly, water). |
8th Mar 2021, 2:55 pm | #88 | |
It’s an interesting comparison, though, given how close the masts are to the A38, and indeed houses, given it’s pumping out 400kW of AM on 198 and 100kW or so each from the other two Txs on MW – those masts even closer to the road. The old BBC building on the Washford site was, at least the last time I went by, a children’s adventure-cum-zoo type place IIRC. Now we’re worrying about 10 watts from an amateur Tx! Even when I was still at school and an SWL with a bit of wire to a admittedly a tallish pole I was getting grief from neighbours “interfering with the telly” and causing an eysore. I can remember some ham cases making it onto TV consumer programmes when the latter started to arrive on our screens. They’d have had a field day with this. ”Have you a radio amateur in your street? Did you know their signals could damage your health? You could be entitled to thousands in compensation! Text HAMITUP now to Sue Grabbit & Runne on 08 bla bla bla...” |
8th Mar 2021, 4:54 pm | #89 |
It is not just for amateurs, but the process is for all installations of RF transmitters, Mobile radio TV, Broadcast hospital radios etc. In most instances the aerial is up a mast of on the roof of the building.
So the local Taxis company that is on the end terrace of the block, or in the town centre etc. will also have to deal with this. Adrian |
8th Mar 2021, 5:28 pm | #90 | |
Yeah, Washford was a Tropic-quarium with exotic birds and other wildlife. It used part of the old transmitter building and the waste heat from the MF transmitters through the wall there to keep the environment toasty. I don't think it exists anymore now. This was back in '89 - '91. When I erected a long-wire after getting licenced I had a particular neighbour round giving me grief about her telly. She wasn't particularly interested that I hadn't anything connected to it, of course. This latest piece of legislation will empower radio amateurs who hitherto have only been concerned with un-neighbourly electrical interference to state categorically that they are running a safe and responsible outfit.
Regds, Russell W. B. G4YLI. |
9th Mar 2021, 8:03 pm | #91 | |
[I wonder if the OFCOM people would know the legal differences between historic Curtilage, Demesne and Messuage as it applies to my QTH?] |
9th Mar 2021, 8:46 pm | #92 | ||
But still alive at 74! My letter to OFCOM:- 'Next year will be my 50th anniversary of obtaining a Full Amateur Licence. It is a shame that your proposals will mean that I may have to go permanently off-air as I cannot afford the professional services required for RF field measurement to comply with your licence variation. It has been a very good hobby but a shame that the H & S requirements have all but destroyed the joy it gave. To comply with the Licence requirement that equipment shall not be made available to any person without a licence, I can confirm that if necessary, all of my equipment will be physically destroyed before taking to the local recycling centre. ' 73 es gd DX, G4CNH now QRT
9th Mar 2021, 9:50 pm | #93 |
Rather than sad and unconstructive moaning about it, has anyone else made a first-attempt at a template to capture the information needed to document and achieve a likely-OFCOM-acceptable level of compliance?
I've been working on something for the last few days and - if you're interested - I will post this [as a Word2019/16.0 .docx] later this week. I'm not saying it will cover _all_ the issues that may apply at your particular QTH, rather that it could serve as a template on which you can easily build your own locally-appropriate case. |
9th Mar 2021, 10:55 pm | #94 | |
Don't forget your hereditaments!
10th Mar 2021, 8:00 am | #95 |
Top Cap, most stations will be able to comply by running one of the spreadsheets or programs readily available to calculate the safe distance (usually just a few metres) and addressing any parts which exceed that. Or if the calculated field strength is less than 10W EIRP just highlight the fact and do nothing more. It is not necessary to hire expensive equipment or consultants unless there is a significant issue. It is certainly not necessary to go QRT and destroy all your equipment, it is not WW3.
73 Dave G3YMC Already compliant QRP station with a few more sunspot cycles still on the clock |
10th Mar 2021, 9:13 am | #96 |
10th Mar 2021, 10:24 am | #97 |
Hmm, it looks like my Topband days are over. Even my modest 30w is too much to allow for my vertical being within 1 metre of a public walkway and literally one brick wall thickness from my neighbour's property. Moving the vertical in any direction just transfers the problem to another place.
Andy G1HBE. Last edited by Andrew2; 10th Mar 2021 at 10:31 am. |
10th Mar 2021, 11:07 am | #98 | ||
one only needs to look at what the commercial sellers are suggesting for on site / industrial uses that even a couple of years ago would be prime licenced PMR territory ... ISM bands 'wi-fi' kit on the basis that many settings now have wi-fi for machinery // computers / RF 'guns' not to mention telematics on MHE fleet ... 'radios' which are wifi terminals |
10th Mar 2021, 11:25 am | #99 |
In my own experience the recent commercial exploitation of RF spectrum has focused largely on UHF and SHF.
In a previous life part of my role was helping to protect free access to international C-band satellite down links from the rollout of UK based WiFi services. The commercial operators had little to zero interest in HF spectrum - it was all about selling services in urban areas and with controlled coverage. |
10th Mar 2021, 12:23 pm | #100 |
I will be contacting Ofcom about this, as there have been no emails from them, whether to renew licence details or otherwise, no letter post either. The only licence emails that I have received have all been of the 'there is a problem with your licence' spamming/fishing type re my tv licence! Which is automatically paid by direct debit. Luckily with using Thunderbird for my emails, it shows if anything has been put in it's trash/spam sections, which I check before closing the program.
Dave Dave
