Old 18th Nov 2023, 8:07 pm   #1
Smithdoor
Smithdoor's Avatar
Default New lathe.
I sold my old South Bend 9A and down sizing to mini lathe.
The old lathe weight was 700 pounds and new lathe is 80 pounds. I'm doing in case I need to move to small place. I still a lathe for winding coils.
https://www.walmart.com/ip/8x14-2250...ore/5116832219
It will here next week
Dave
Smithdoor is offline
Old 18th Nov 2023, 9:09 pm   #2
Cruisin Marine
Default Re: New equipment
Nice one, those South Bend's are massive machines- but nice. I only possess a lowly Myford ML4, a very old lathe.
"Behind every crowd, there's a silver Moonshine"
Cruisin Marine is offline
Old 18th Nov 2023, 9:27 pm   #3
Radio Wrangler
Radio Wrangler's Avatar
The Drummond/Myford M series was a copy of a South Bend. and the circle is completed!
Radio Wrangler is offline
Old 22nd Nov 2023, 6:40 am   #4
Smithdoor
Smithdoor's Avatar
New lathe in my shop
Dave
Old 22nd Nov 2023, 11:32 am   #5
Lloyd 1985
Lloyd 1985's Avatar
I was thinking of buying one of those small lathes, I already have a little lathe, but the belt is on its last legs, and they seem rather hard to source! Plus I just fancied an upgrade…
Regards
Lloyd
Lloyd 1985 is offline
Old 22nd Nov 2023, 12:26 pm   #6
Electronpusher0
Dave
That's almost identical to mine. I bought it second hand and it came with a 4 jaw chuck, I bought a 3 jaw and have not had a need to use the 4 jaw since.
Peter
Electronpusher0 is offline
Old 22nd Nov 2023, 6:00 pm   #7
ex 2 Base
There are plenty of pre owned lathes available on Model Eng. forum. I believe Boxford is a UK copy of South Bend and there was a copy made in VK land. Schools way back, had Boxford lathes so plenty around, a bit big and clumsy for coil winding, nice vee bed though, unlike Myford flat bed. Regarding 4 jaw chucks, once you get the hang of using one you will dispense with the 3 jaw, 4 jaw is so versatile. Ted
ex 2 Base is offline
Old 23rd Nov 2023, 1:48 pm   #8
wd40addict
wd40addict's Avatar
Looks like the generic Chinese lathe that pops up under a number of brand names and with different options. I have the Machine Mart version and initially had problems with poor adjustment ex-factory of the gibs on the cross slide.
wd40addict is offline
Old 23rd Nov 2023, 5:18 pm   #9
Smithdoor
Smithdoor's Avatar
My lathe is under several names .
The model is PV210V.
Anything I buy new or used I check adjustment. The bouncing in shipping will loosen everything.
Dave
Old 24th Nov 2023, 3:22 pm   #10
Smithdoor
Smithdoor's Avatar
If read ads on South Bend Lathe a lot of electronic manufacturers used the 9A and the older version.
I found very handy for making knobs, Coils even probes and the list goes on.
Today I keep a inventory of brass and aluminum for making parts . Most faster to make part than find on internet
Dave
Old 29th Nov 2023, 12:20 pm   #11
Smithdoor
Smithdoor's Avatar
Default Re: New lathe.
Photo of lathe in use
Name:	1) Avatar mini mathe 11 27 23.jpg
Old 30th Nov 2023, 10:34 am   #12
jez_145
Originally Posted by ex 2 Base View Post
..... Regarding 4 jaw chucks, once you get the hang of using one you will dispense with the 3 jaw, 4 jaw is so versatile. Ted
Yes, when I was an apprentice, we had a wide range of lathes to work with. The first thing I did whenever I encountered one fitted with a three jaw chuck was to immediately replace it with a four jaw. I got very adept at using a dial gauge! The main problem with three jaw chucks is that they NEVER run perfectly true. This is not a problem if you're only turning one end of a workpiece and then parting off. But, for me, this was hardly ever the case. Turn the workpiece round and you can end up with one end a fair few thou out relative to the other. Also, you can reverse the jaws of a four jaw - which is very handy at times.
Jerry
jez_145 is offline
Old 30th Nov 2023, 11:31 am   #13
Station X
Station X's Avatar
These forums are not the place for detailed discussions about the use of machine tools, it's more appropriate for Model Engineering and similar forums.
Thread closed.
Graham. Forum Moderator
Station X is offline
