#21 | |
![]() Quote:
I have'nt plugged it in yet. I also resoldered the wires from the contacts. I've attached a pic |
#22 |
That sounds good, but your original element had a resistance 0.538 kilohms ie 538R, so I don't understand why you've changed it.
#23 | |
![]() Quote:
From the figures I 've just given i'm wondering if I should plug it in. |
#24 |
Quite. Mains powered. So for a 520 ohm heater resistance the power dissipated is (230^2)/520 = 102W, which is pretty much bang on for a 100W soldering iron.
Even if mains was at its (current) minimum of 230V - 6% (216.2V) the heater would dissipate 90W. So there seems to have been nothing wrong with the original element. Craig
Doomed for a certain term to walk the night |
#25 |
#26 |
262R fits in with it being 200W.
#27 |
Zero or infinite
![]() ![]() Les. |
#28 |
Time to plug in the 100W iron methinks.
#29 |
#30 |
#31 |
If it's an RCD that's tripping that suggests an insulation breakdown, probably between the element and the iron's metal work. I assume a three core flex is fitted?
#32 |
yes, 3 core flex
#33 |
With the tip inserted you were able to read the resistance of the element between the live and neutral pins of the mains plug. Under the same conditions what resistance do you see between the Live/Neutral pins and the earth pin?
#34 |
Thanks, can't check for about two hours.
#35 | |
![]() Quote:
L to E 4.07M ohm N to E 4.55M ohm with the tip out L to N 0.529k ohms L to E 3.94 M ohms N to E 4.55 M ohms many thanks |
#36 |
Let me try an aside on this existing thread.
I want to take a 24v Weller TCP away with me, but don't want to pack the base unit. Can I power it from a DC source (Wall wart or two car batts in series), or does the DC interfere with the control. Maybe polarity would effect sensing temp? Thanks, Les. |
#37 |
The thermostat contacts will weld if used on a DC supply.
Leon. |
#38 |
Why? What is the difference between 24V RMS AC and 24V DC?
Craig
#39 |
Contact sparking/arcing is worse with DC as AC passes through zero 50/60 times per second extinguishing the arc.
Alan G6PUB, BVWS |
#40 |
100/120 times.
Leon. |
