Reply
Old 28th Jul 2023, 8:58 pm   #1
sparkymike
Default Marconi Record 'G' clamp
I picked up one of these clamps today. Anyone know what they were used for in the Marconi works ? The large canister is sprung loaded, so pressure would still be applied if the item in the jaws reduced in thickness (shrunk) a little.
Mike.
sparkymike is online now   Reply With Quote
Old 28th Jul 2023, 9:34 pm   #2
Dickie
Default Re: Marconi Record 'G' clamp
They were the business end of the Marconi moisture meter range, TF933 and its variants. You put the sample to be measured in the holder, squashed it as far as you could, and the instrument measured the conductance of the sample.
Regards,
Richard, BVWS member
Dickie is online now   Reply With Quote
Old 29th Jul 2023, 8:40 am   #3
sparkymike
Thanks Richard. In that case I doubt if I will ever use it for its original purpose, but could be useful to put a constant pressure on wooden items to ease excess glue out of a joint.
Mine is missing the extra bar, but the bolt holes are there and Marconi ident.plate has gone.
Mike.
Old 29th Jul 2023, 11:27 am   #4
Dickie
Unless you happen to be an arable farmer you won't have much use for it. Back in the 50's, 60's and even 70's they were the gold standard that every farmer relied on to know when his grain (and even tobacco) was dry enough to be stored.
Regards,
Old 29th Jul 2023, 12:47 pm   #5
factory
Some of these TF933 meters seem to still be in use, lots of info here; https://thefarmingforum.co.uk/index....surance.73614/
factory is offline   Reply With Quote
Old 18th Nov 2023, 7:51 pm   #6
Lodekka
I can repair and calibrate Marconi Moisture Meters. If you have no use for the G clamp assembly then I could find a home for it...
Lodekka is offline   Reply With Quote
Reply
