Old 20th Nov 2023, 5:08 pm   #21
sigmolio
Default Re: Weller soldering iron.
Originally Posted by Station X View Post
With the iron cold what resistance do you measure between the Live and Neutral pins of the mains plug? If you see an open circuit work your way round until you locate the break. My money's on dirty contacts.
I found a spare heating element and put that in. At the plug, without the iron tip inserted, and between live and neutral pins , I get 26M ohms rising to 36M ohms. With the tip in (and therefore the contacts closed) i get a steady 0.52kohms which I think is close to the value of just the heating element alone.
I have'nt plugged it in yet. I also resoldered the wires from the contacts.
I've attached a pic
sigmolio is offline   Reply With Quote
Old 20th Nov 2023, 5:30 pm   #22
That sounds good, but your original element had a resistance 0.538 kilohms ie 538R, so I don't understand why you've changed it.
Old 20th Nov 2023, 5:51 pm   #23
sigmolio
My apologies. I had an old iron on the bench (that also doesn't work) and gave you the wrong measurements.
From the figures I 've just given i'm wondering if I should plug it in.
Old 20th Nov 2023, 6:12 pm   #24
Craig Sawyers
Craig Sawyers's Avatar
Quite. Mains powered. So for a 520 ohm heater resistance the power dissipated is (230^2)/520 = 102W, which is pretty much bang on for a 100W soldering iron.
Even if mains was at its (current) minimum of 230V - 6% (216.2V) the heater would dissipate 90W.
So there seems to have been nothing wrong with the original element.
Craig
Doomed for a certain term to walk the night
Craig Sawyers is online now   Reply With Quote
Old 20th Nov 2023, 6:22 pm   #25
sigmolio
Also I have a Weller 200W which works fine.
At the plug, with the tip in it reads 262 ohms. Tip out it reads zero.`
Old 20th Nov 2023, 6:32 pm   #26
262R fits in with it being 200W.
Old 20th Nov 2023, 6:33 pm   #27
MotorBikeLes
Zero or infinite
Les.
MotorBikeLes is offline   Reply With Quote
Old 20th Nov 2023, 7:03 pm   #28
Time to plug in the 100W iron methinks.
Old 21st Nov 2023, 12:24 am   #29
sigmolio
Originally Posted by MotorBikeLes View Post
Zero or infinite
Les.
Gotta be infinite I guess.
Old 21st Nov 2023, 12:28 pm   #30
sigmolio
Plugged it in without the tip, the barrel started to warm then the RCD tripped. I thought it could only heat up with the tip inserted.
Old 21st Nov 2023, 12:39 pm   #31
If it's an RCD that's tripping that suggests an insulation breakdown, probably between the element and the iron's metal work. I assume a three core flex is fitted?
Old 21st Nov 2023, 1:13 pm   #32
sigmolio
yes, 3 core flex
Old 21st Nov 2023, 1:18 pm   #33
With the tip inserted you were able to read the resistance of the element between the live and neutral pins of the mains plug. Under the same conditions what resistance do you see between the Live/Neutral pins and the earth pin?
Old 21st Nov 2023, 2:30 pm   #34
sigmolio
Thanks, can't check for about two hours.
Old 21st Nov 2023, 6:31 pm   #35
sigmolio
With the tip in : L to N 0.511k ohm
L to E 4.07M ohm
N to E 4.55M ohm
with the tip out L to N 0.529k ohms
L to E 3.94 M ohms
N to E 4.55 M ohms
many thanks
