Old 31st Oct 2023, 9:15 am   #1
ChasL001
ChasL001's Avatar
Default Triumph CR 1610
Hello all,
I have a Triumph CR 1610 cassette "data" recorder in for repair. Am looking for a manual or circuit diagram. I know this is probably a White Label buy in by Dixons in the 80s but it's a good recorder in that it's auto level works well in terms of computer program playback and recording, which is why the owner wants it fixed.
So, maybe this model may be know under other brand names.
Any help or links gratefully received.
Pic attached for reference.
Thanks
Chas.
Name:	Triumph CR1610.jpg
ChasL001 is offline   Reply With Quote
Old 2nd Nov 2023, 10:23 am   #2
DMcMahon
DMcMahon's Avatar
Default Re: Triumph CR 1610
A long shot Chas but have you looked inside the recorder in case there are any OEM markings as to make/model ?
For example sometimes on rebadged units removing the badged name label reveals the original maker/model details.
DMcMahon is offline   Reply With Quote
Old 2nd Nov 2023, 10:48 am   #3
DMcMahon
DMcMahon's Avatar
The label picture at Post 4 of this linked Thread does support Triumph being a brand done for Currys -
https://www.google.com/url?client=in...ax91d-ek-OS0EQ
Old 2nd Nov 2023, 1:53 pm   #4
wd40addict
wd40addict's Avatar
What's actually wrong with it?
wd40addict is offline   Reply With Quote
Old 2nd Nov 2023, 2:30 pm   #5
ben
ben's Avatar
I had one badged by Boots. It needed a new flat belt IIRC.
What's wrong with that one?
Ben.
Old 2nd Nov 2023, 4:11 pm   #6
G6ONEDave
G6ONEDave's Avatar
Hi Chas, If it helps I have a photocopied service manual that I could scan and email to you. Please PM me if this would help you.
Dave
Quote "All is hyperthetical, until it isn't!" (President Laura Roslin, Battlestar Galactica)
G6ONEDave is offline   Reply With Quote
Old 2nd Nov 2023, 4:26 pm   #7
Nickthedentist
Nickthedentist's Avatar
Standard £20 job from about 1987. I’ve seen them badged as all kinds of things including “Cloud 9”!
Think a tiny circuit diagram was often included in the instruction booklet.
Nickthedentist is online now   Reply With Quote
Old 3rd Nov 2023, 4:03 pm   #8
G6ONEDave
G6ONEDave's Avatar
The service manual states that this model was specifically for computer program use.
Dave
Old 3rd Nov 2023, 4:14 pm   #9
Dave
Usually meaning that the automatic level control on the record side was either recalibrated to better deal with the rather coarse but consistent-in-level CUTS tape-recording tones, or deleted altogether....
I played a blank tape at full volume. The mime-artiste who lives next door complained.
G6Tanuki is online now   Reply With Quote
Old 3rd Nov 2023, 4:40 pm   #10
DMcMahon
DMcMahon's Avatar
It has a changeover switch to switch from Normal to Compute Mode On.
The User manual cover calls it a Portable Cassette Recorder Computer Compatible.
So it sounds like when switched to Normal it would operate as a standard audio cassette unit.
Old 3rd Nov 2023, 11:07 pm   #11
TIMTAPE
From memory it looks like a Sharp shoebox.
TIMTAPE is offline   Reply With Quote
Old 4th Nov 2023, 12:14 am   #12
ben
ben's Avatar
In my experience, the computer/norm switch on such units does one of two things: adjust the frequency cut/boost to suit the data (usually cuts the bass and very top, and boosts the middle) or enables low level monitoring via the speaker while recording or playing.
Ben.
