Old 30th May 2018, 6:05 pm   #1
Gridiron
Default 3 Ghz Resonant Cavity
Does anyone know what this was part of, possibly from a radar system or test gear for radar? The cavity is brightly plated and has a moveable piston controlled by a spindle. The cylinder on one side contains a CV285 diode valve, which is for use at 3 GHz.
Mike.
Name:	Resonant chamber 3 GHz 1.jpg
ID:	163843   Click image for larger version
Name:	Resonant Chamber 3 GHz 2.jpg
Gridiron is offline
Old 30th May 2018, 6:12 pm   #2
G6Tanuki
G6Tanuki's Avatar
Default Re: 3 Ghz Resonant Cavity
The construction style and connectorage does definitely hint at a military/avionics application, from the late-1940s or the 1950s.
[To be honest there would not have been anything using those frequencies in the 'fifties except for stuff like Radar]
Could it have been some sort of wavemeter? The small tubular stub on the right looks like it may have some sort of calibration-points on it, but the image is out of focus in that area.
G6Tanuki is offline
Old 30th May 2018, 7:50 pm   #3
Jon_G4MDC
Jon_G4MDC's Avatar
Can be pretty sure it is a wavemeter, in the second picture a small coupling loop to the diode is clearly seen. The input cable (black co-ax) probably has something similar but it is out of shot and hidden by the cavity body, or it could just be a probe wire.
Most likely driven by a sniffer (or directional coupler - luxury) and used to confirm the radar rig was running where intended.
Silver plating is in very good nick for the age!
Jon_G4MDC is offline
Old 30th May 2018, 10:26 pm   #4
Gridiron
The two screws in the first photo are on an index which moves with the piston when the spindle is turned, there is one line engraved on this and one line on the body of the device which the index can be lined up with, no other markings or labels are on it.
Mike.
Gridiron is offline
Old 30th May 2018, 11:08 pm   #5
Julesomega
Julesomega's Avatar
In its Pye-blue finish it looks like it could have been part of the 4GHz Wireless Set No. 10
- Julian
It's good here
Julesomega is offline
Old 31st May 2018, 11:41 am   #6
Malcolm G6ANZ
Malcolm G6ANZ's Avatar
I've got one similar sitting in the garage. I rescued it from work where it was used to set the frequency of a pair of resonant cavities. The cavities were set to be just above and just below the resonant frequency of a clinical linear accelerator. The operation frequency of the accelerator was 2998Mhz. The output from the cavities was used to tune the magnetron the stay on the acceleratror's frequency. The accelerator having a very high Q factor the frequency was critical.
The vernier dial is calibrated in MHz. I beleive the whole device is silver plated.
The writing above the labelled 'input' says
"wavemeter type 1662 AM ref 10T/6089"
Malcolm
Malcolm G6ANZ is offline
