17th Feb 2020, 1:18 am | #1 |
Philips car radio transistor output
hi i have a philips n4g93vt hybrid car radio. the ouput valve is an ef98.
i have the circuit diagram however what i dont have is the second part of the radio that contains the transistor. the transistor is an oc26 on the circuit diagram it shows 2 transformers i could possible build the final output stage. However how do i work out what transformers i need?? |
17th Feb 2020, 11:03 am | #2 |
Re: philips car radio transistor output
There is some guidance in "Mullard Manual of Transistor Circuits" detailing a single-ended OC26 output stage for car radio. The section starts on page 137 of the "Class A Output Stages" Chapter.
Ron |
17th Feb 2020, 5:04 pm | #3 |
Re: Single-ended Transistor amps.
I am looking for a transformer to run an oc26 off an ef98 valve how ever i don't have much to go on other than 25:1 and 270 ohms
17th Feb 2020, 8:12 pm | #4 |
Re: Philips car radio transistor output
If it was mine I would build the external unit using a modern IC amplifier, loading the EF98 to look like what the transformer was, if it hasn't already got an anode resistor.
18th Feb 2020, 7:13 am | #5 |
Winding details for the Mullard transformer are given in the Mullard "reference manual of transistor circuits"
Ed |
19th Feb 2020, 2:17 pm | #6 |
this is the schematic as you can see with out the transistor side there is no load on the anode. i have attached the circuit for reference.
21st Feb 2020, 12:55 pm | #7 |
How important is it for you to duplicate the original circuit?
Making a audio amplifier using two unusual transformers could be expensive, bulky and time consuming. You could amplify the output from the EF98 using a readily available audio amplifier chip or possibly a MOSFET source follower. |
