9th May 2023, 9:09 pm | #1 |
ITT Pinto radio
Hi.
I have an ITT Pinto radio and I need help. There is no sound from the radio. Loudspeaker is OK, transformer is OK, but there is no sound. Where must I look? |
9th May 2023, 9:17 pm | #2 |
Re: ITT Pinto radio
Hi and welcome to the forum
Just to confirm the radio's identity I have taken a picture from the Crackles web site (now sadly RIP). Have you checked the earpiece socket (it mutes the speaker when the earpiece is inserted and the contacts get dirty). Also check the on off switch and that there are no cracks (dry joint) on the pcb soldered joints. Cheers Mike T
Invisible airwaves crackle with life or at least they used to Mike T BVWS member. www.cossor.co.uk Last edited by Cobaltblue; 9th May 2023 at 9:22 pm. Reason: additional info |
9th May 2023, 9:21 pm | #3 |
Re: ITT Pinto radio
9th May 2023, 9:24 pm | #4 |
Re: ITT Pinto radio
9th May 2023, 9:35 pm | #5 |
Re: ITT Pinto radio
I can repair tube radios but I don't have information transistor radios. The on off knob is OK but I don't know how to check earpiece socket, the socket has 4 wires.
Last edited by Station X; 10th May 2023 at 8:06 am. Reason: Forum rule compliance. |
10th May 2023, 5:29 am | #6 |
Re: ITT Pinto radio
Hi there.
My hobby is tubes radios and I have some information about it but I haven't information about transistor radios. I have looked transistor radios on internet pages and the earpiece socket may be faulty but I don't know how to check this socket and how to bypass this socket. This socket has 4 wires. Will I replace electrolytic capacitors? Last edited by Station X; 10th May 2023 at 8:11 am. Reason: Forum rule compliance. |
10th May 2023, 8:10 am | #7 |
Re: ITT Pinto radio
A fault which causes a radio to be completely dead should be easy to find.
Check the battery/mains changeover switch. Use you meter to check that power is actually reaching the radio. Clean the contacts on the ear piece socket.
10th May 2023, 8:17 am | #8 |
Re: ITT Pinto radio
I have attached a snip of the circuit for the earpiece socket.
It looks like 2 of the wires will go to the same place on the sockets and this is the common connection. so the output connection and the loudspeaker connection are the two you need to join together. Cheers Mike T
10th May 2023, 10:53 am | #9 |
Re: ITT Pinto radio
Headphone socket pictures
10th May 2023, 11:01 am | #10 |
Re: ITT Pinto radio
There are 3 wire ,white,brown , and yellow but the yellow have a shield and white wire.the yellow wire connect on pcb board.
10th May 2023, 11:47 am | #11 |
Re: ITT Pinto radio
Just clean or bridge the contacts surrounded in red. Have you checked the other points I suggested?
10th May 2023, 1:32 pm | #12 |
Re: ITT Pinto radio
Dear Graham I will chek your suggestions but I don't undersand some points,
are there two switch in radio 1-battery-mains changeover switch 2-on-off switch if there are two switch please write me ;I will measure which points on circuit. Last edited by Station X; 10th May 2023 at 3:08 pm. Reason: Forum rule compliance |
10th May 2023, 3:13 pm | #13 |
Re: ITT Pinto radio
There are two switches in the path supplying DC voltage to this radio.
1. The battery/mains switch is operated when you plug the mains cord or flex into the radio. When plugged in it switches between the battery and the internal mains power supply unit of the radio. I have coloured it red on the attached extract from the circuit. 2. The OFF/ON switch is operated when you turn on the radio. I have coloured it blue on the attached extract from the circuit. It supplies power to the radio from the internal battery or internal mains power supply unit depending on whether or not the power cord is inserted. You need to use your test meter to prove continuity through these switches and check that power is reaching the radio. A good initial check would be to check the voltage across C701 with the set connected to the mains supply. Expect to see approximately 9 Volts. PS. Check the 315mA mains fuse for continuity.
10th May 2023, 7:21 pm | #14 |
Re: ITT Pinto radio
Hi Graham I measured c701 between two legs and it is 12vdc
10th May 2023, 7:25 pm | #15 |
Re: ITT Pinto radio
A bit high, but the PSU could be off load. What DC voltages are you measuring from the tags of the OFF/ON switch to chassis?
11th May 2023, 7:41 am | #16 |
Re: ITT Pinto radio
Hi Graham
I measured these two points(red marked) when the on- off switch open.perhaps the battery-mains switch may be faulty |
11th May 2023, 7:48 am | #17 |
Re: ITT Pinto radio
You should have measure 12V on the top contact as it's connected to C701 and you've already measured 12V there.
What do you measure on the other tag, ie the wiper? If it's zero volts then clean or bridge the switch.
11th May 2023, 8:35 am | #18 |
Re: ITT Pinto radio
sory sory, I forget schema
11th May 2023, 9:04 am | #19 |
Re: ITT Pinto radio
OK.
So you're measuring 12V DC between the two red arrows. Now check that the 12V is passing through the BATTERY/MAINS switch and the OFF/ON switch and is reaching Fe304 and Fe405.
12th May 2023, 7:01 am | #20 |
Re: ITT Pinto radio
Hi Graham
I found the problem , battery-mains switch was faulty. Just now the radio is working perfect but the speaker(1.5watt) no strong. Thanks for your help. |
