2nd Jan 2023, 10:37 pm | #1 |
Pye Shaver Mics
Hi All,
Found a seemingly unused Pye Shaver Mic in a recently acquired box of bits and thought I would try to use it. Never having used one of these before I took it to bits to trace the wiring and found that there is active circuitry in the mic. two little PCB's, one where all the wiring terminated with a few passive components and another wired to the first which appears to have 3 transistors and a few more bits. Is anybody able to shed any light on what function these circuits perform? The insert is an electret so I was expecting a power feed but not all this additional stuff. cheers Peter G8BBZ
Peter G8BBZ |
2nd Jan 2023, 10:49 pm | #2 |
Re: Pye Shaver Mics
Hi Peter.
You found a modern one. After all that time back in 1968 at Haig rd with the old basic Westminster cloth covered curly lead microphone! The passive component pcb is just for power and audio functions for the electret insert. It can be configured for am or fm response. I should have circuit info.....somewhere? The other one is I believe for a time out function on ptt? Blue and white are I think ptt. I have seen them before but never used the function. Best wishes for 2023 Rob
3rd Jan 2023, 10:44 am | #3 |
Re: Pye Shaver Mics
I think these are the circuits you are after.
They were appendices in the MX294 handbook. |
3rd Jan 2023, 3:46 pm | #4 |
Re: Pye Shaver Mics
Hi Robin,
Thought you might be monitoring. Best wishes for 2023. Hi Jon, Thanks for the ccts. just what i wanted. cheers Peter G8BBZ
Peter G8BBZ |
3rd Jan 2023, 4:06 pm | #5 |
Re: Pye Shaver Mics
Glad it's what you needed.
The mic schematic is for FM. I suppose for AM they messed about with some RC values. It was all a dodge to get improved readability by adding some extra pre-emphasis that didn't get measured during type approval tests. The Mic didn't form part of the measuring setup. |
3rd Jan 2023, 6:02 pm | #6 |
Re: Pye Shaver Mics
I used one of those shaver mics with a Pye Europa ( I think ) when it was installed in my car. I was on call for British Gas in 1981. I remember the radio set had orange coloured edge operated knobs, which matched the orange push to talk button on the mic.
Cheers Aub
3rd Jan 2023, 6:08 pm | #7 |
Re: Pye Shaver Mics
Europa (MF6FM) had black edgewise controls. It's mate the Reporter (MF5AM) had an orange power button matching the mic but white edgewise controls.
The Gas was always FM AFIK. I'm thinking something like a Pegasus M252 as the only one with orange controls. It was FM. A ruggedised thing built in a diecast chassis getting on for 4" high. Usually drab green. |
3rd Jan 2023, 6:26 pm | #8 |
Re: Pye Shaver Mics
Wrong way Jon!
You do have the knob colours correct though. MF5AM is the old 2W nominal Motafone. Horrible things with built in speaker. MF6AM is the Reporter, (solid state) Not to be confused with the ancient valve one with the same name! MF5FM is vhf fm, nominal 5W, MF25FM is vhf, nominal 25W MF5U is the uhf, nominal 5W I wonder if Aub is thinking of the Olympic M201AM? That had orange mute knob, power button and a tapered orange stripe on the volume knob. AFAIK Gas and electric were on split D/B band am only in those radio model days. BTW, I have a Europa look alike, the SSB170 HF tx/rx. Quite scarce. Apart from the legends on the 3 knobs, (I think one is "clarifier"), it looks the same. As an aside, years ago I once had a junk stall at a rally with a few A200 linears on it. One chap was sorting each one looking at the serial number plate. I assured him they were legit. His reply was "I am looking for the UHF one"! When I said there was no such thing made, he replied that I was wrong, his mate was a Pye engineer and had one! Little did he know.... Rob
3rd Jan 2023, 6:26 pm | #9 |
Re: Pye Shaver Mics
The one's I have seen were AM.
"Behind every crowd, there's a silver Moonshine" |
3rd Jan 2023, 6:35 pm | #10 |
Re: Pye Shaver Mics
Yes thanks for putting that to bed.
I had a few boo-boos in there. I stand corrected. Gas was AM historically. But didn't it go trunked later? That would be FM and maybe what I was thinking. It is very likely that M201 Olympic is the set in question here. MF5AM Motafone - Suflex capacitors short circuit - Yuk! I would have agreed about the A200. Never seen a UHF one. A word of warning about shaver mics. They can come apart in the middle of an over. The top piece - chromed aluminium carrying the insert is only pressed through the plated steel spine which holds all the bits. Sometimes they didn't apply enough pressure with the press. One of mine exploded mid sentence and I was left holding just the spine and a dangling top piece + insert. The plastic side covers were on the floor of the car. Last edited by Jon_G4MDC; 3rd Jan 2023 at 6:52 pm. |
3rd Jan 2023, 7:51 pm | #11 | |
Re: Pye Shaver Mics
Aub
