Old 25th Dec 2022, 10:46 pm   #1
murphyv310
murphyv310's Avatar
Default BNOS LPM144-25-160 linear amp help.
Hi.
I was recently given one of these old Linear amps as it was destined to the bin!
It has two faults.
1..... The preamp has burned out, allegedly caused by a faulty relay that as yet I cannot confirm or otherwise, the issue is there is no circuit diagram with values and in this case the resistors are dust! If someone has one can they please photograph the preamp section with high resolution and upload it as a zip file or PDF so the forum software doesn't make it illegible.
2....... Although I've not tested this it is distorted on TX on both SSB & FM, rated output power is OK apparently, any pointers would be useful but I do suspect the PA bias is most likely the issue.
Any help would be greatly appreciated. Even a scrap board with the preamp intact.
Cheers,
Trevor.
MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member
murphyv310 is offline
Old 28th Dec 2022, 9:59 am   #2
murphyv310
murphyv310's Avatar
Default Re: BNOS LPM144-25-160 linear amp help.
Hi.
Anyone able to help me with this or is this now a lost cause?
Cheers,
Trevor.
Old 28th Dec 2022, 11:13 am   #3
mickm3for
Hi a poor copy of the circuit from George Smart may be he has other stuff, on his web site he details repair of a 144-100 Mick
mickm3for is offline
Old 28th Dec 2022, 12:07 pm   #4
Terry_VK5TM
Terry_VK5TM's Avatar
There's some reasonably clear photos in this thread https://www.vintage-radio.net/forum/...d.php?t=157730
Terry VK5TM
https://www.vk5tm.com/
Terry_VK5TM is offline
Old 28th Dec 2022, 1:06 pm   #5
ms660
ms660's Avatar
So far as I can make out from Trev's photo....from left to right....68 Ohm, 12 or 120 Ohm ?, 68 Ohm...R34, R33 & R35 respectively on the schematic.
Lawrence.
ms660 is offline
Old 28th Dec 2022, 1:29 pm   #6
Radio Wrangler
Radio Wrangler's Avatar
It's likely tat the power amp areas are simply slight variations on a Motorola applications note for those transistors.
Radio Wrangler is offline
Old 28th Dec 2022, 1:42 pm   #7
ms660
ms660's Avatar
Re:Post#5: Looking again, R33 could be 120 Ohms as that resistor network would then work out to 50 Ohms which would match the strip line.
Lawrence.
ms660 is offline
Old 28th Dec 2022, 2:29 pm   #8
Jon_G4MDC
Jon_G4MDC's Avatar
This is the exact damage you would expect from TXing up the input while the power supply is off. Relays can't switch so the preamp output pad is fried.
If you are lucky the BF981 might have survived.
As for the TX side distortion on SSB is probably bad biasing. Distortion on FM is probably down to something else entirely.
Jon_G4MDC is offline
Old 28th Dec 2022, 10:35 pm   #9
murphyv310
murphyv310's Avatar
Thanks guys
Now have the info I require.
The BF981 Is shorted all ways, the resistors that are cooked are 2x 68r, 220r and the 1 watt 330r. The decouplers will routinely be replaced. The bias transistor has an open circuit B/E junction.
Hoping to get a result once I've got a BF981, A genuine device is ordered.
Cheers,
Trevor.
Old 29th Dec 2022, 12:27 pm   #10
G6ONEDave
G6ONEDave's Avatar
Don't forget the 2 x 1N4148 (or similar) signal diodes being used to clamp the input of the pre-amp. They've probably been damaged as well.
Dave
Quote "All is hyperthetical, until it isn't!" (President Laura Roslin, Battlestar Galactica)
G6ONEDave is offline
Old 29th Dec 2022, 2:35 pm   #11
Jon_G4MDC
Jon_G4MDC's Avatar
Maybe. On further reflection I think there could be some issue with the relay switching as OP stated.
The preamp seems to have a bypass relay so TXing into the unit with the power off should not have damaged the preamp pad. The RF would have taken the preamp bypass route instead. Obviously it hasn't...
Old 30th Dec 2022, 7:38 pm   #12
murphyv310
murphyv310's Avatar
First thing to test will be the preamp on receive with no RF power from the transmitter.
Next of course is to manually check the switching of the relays prior to feeding it with any RF.
The 1N4148 protection diodes oddly are 100%
Cheers,
Trevor.
Old 30th Dec 2022, 8:14 pm   #13
Jon_G4MDC
Jon_G4MDC's Avatar
Good. I expected that. I think they made the designer happy and that's about it.
