Old 9th Feb 2017, 11:31 am   #1
dominicbeesley
dominicbeesley's Avatar
Default Damage from out of spec line rates
A quick LOPT question...
I am building an 8-bit computer and would like to test my work so far. I am waiting for a 48MHz crystal to run the system clocks (divided down). At the moment I just have a 50MHz crystal and the line/frame signals generated are about 4% fast. Is that likely to damage my Sony PVM-2010 monitor, I know too slow can be bad....is 4% likely to be much too fast?
Thanks
Dom
dominicbeesley is offline
Old 9th Feb 2017, 12:14 pm   #2
kan_turk
kan_turk's Avatar
Default Re: Damage from out of spec line rates
Hi Dom
4% fast should not cause a problem as:
1. Magnitude of discrepancy is relatively modest
2. Faster generally has less impact than slower
Hope this helps
Rgds
kan_turk is offline
Old 9th Feb 2017, 1:34 pm   #3
dominicbeesley
Thanks John,
I thought not, but best to check...I'll give it a try tonight hopefully
Old 10th Feb 2017, 2:02 am   #4
dominicbeesley
Thanks for the advice, I thought I'd report back
Well, I gave it a try and it didn't cause any smoke but wasn't overly stable. It seems the Sony is a bit fussy! At 61.4us a line it was definitely unhappy (see first pic). In the end I just faffed one of the registers on the CRTC chip a little and now it is closer to spec (63.36us) and happier. I should have thought of that earlier!
It seems that though the Sony is fussy it is not easily damaged, due to some mishaps it has been fed everything from 1kHz line rates to 40kHz and other than going out of sync didn't even make a squealing noise, I will have to dig out the schematic and see if this has a separate EHT oscillator.
It might be time to move on from breadboard tomorrow...
D
ID:	137338   Click image for larger version
ID:	137339   Click image for larger version
Old 11th Feb 2017, 4:14 am   #5
Argus25
No Longer a Member
The good news as Kan Turk points out, a faster line rate is no problem (If the set's horizontal hold/AFC system can lock to it). In this case the horizontal deflection transistor is held on for a shorter period of time than with a standard frequency signal. Therefore less magnetic field energy is stored in the yoke and line output transformer at the end of scan (beam at right side of the raster) so the picture width will be a little less and also at flyback, the flyback peak voltage on the collector of the H output transistor a little less and the EHT a little less too.
On the other hand a lower H rate signal, if the set could lock to it, increases the width and EHT , all other things equal.
However the beauty of TV's and most computer monitors, is that their internal horizontal oscillators and AFC system have a limited locking range, so that they simply won't lock to an H rate that is too low or too high, so they can't be damaged with a non standard video signal/sync or even when the video signal is just gross noise, like the noise between TV channels.
However, horrifyingly, there was a class of early computer monitor that didn't actually have an internal horizontal oscillator of its own. It relied on the feed from the computer. These are notorious for failure if fed with a non standard signal.
Argus25 is offline
