Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Service Manuals, Circuit Diagrams and Data Sheets Wanted
Service Manuals, Circuit Diagrams and Data Sheets Wanted If you need help finding service data post a message here. Please do not request or offer data that is available from www.service-data.com
Reply
Old 4th Apr 2024, 5:13 pm   #1
EmleyTim
EmleyTim's Avatar
Default Dansette Capri Record Player Service Sheets Required
Hello All
I’ve recently acquired a Dansette Capri Record Player that requires repair.
Paul’s excellent site draws a blank when searching for service data sheets for valve amplifier versions.
I’m sure that it will be the same or similar to other players of the same era. I’ve yet to work out how to get the moulded front off to release the transit clips and access the (valve) amplifier - the motor board on this model isn’t removable so it would seem to be front access only.
The forward most valve is a UCL82.
Can anybody provide service data on this model please to avoid me reverse engineering it (or a steer towards where I should be looking top right)?
It may be that a valve amp has been retro fitted as there is a distinct lack of vents.
I find this player very attractive in navy blue and cream and look forward to repairing it.
Thanks in anticipation, Tim
ID:	295844   Click image for larger version
EmleyTim is offline   Reply With Quote
Old 4th Apr 2024, 7:54 pm   #2
AC/HL
AC/HL's Avatar
Default Re: Dansette Capri Record Player Service Sheets Required
You're probably right, it's not likely to vary much from the 14-2 (UCL83)
AC/HL is offline   Reply With Quote
Old 5th Apr 2024, 6:59 am   #3
FIXITNOW
FIXITNOW's Avatar
this is the only one i could find but seems not on sites list (only seems to be mk1) so have added
Bermuda mk 2
FIXITNOW is online now   Reply With Quote
Old 5th Apr 2024, 7:33 am   #4
EmleyTim
EmleyTim's Avatar
Thanks very much for your input both.
I’ll use the Bermuda as a starting point and go from there.
Old 5th Apr 2024, 10:16 am   #5
G6ONEDave
G6ONEDave's Avatar
Thought that this is the the link to service info from the top right link to the parent site; https://www.service-data.com/product...03/1490/a11103 All I did was search for 'Capri', sereral returns but the first one appears to be the requested Dansette.
Dave
Quote "All is hyperthetical, until it isn't!" (President Laura Roslin, Battlestar Galactica)
G6ONEDave is offline   Reply With Quote
Old 5th Apr 2024, 10:59 am   #6
Station X
Station X's Avatar
I'm afraid that's the service manual for a transistor radio. The name "Capri" was applied to several different products.
Graham. Forum Moderator
Station X is online now   Reply With Quote
Old 5th Apr 2024, 2:54 pm   #7
EmleyTim
EmleyTim's Avatar
Thanks Dave but I’d already established what Graham has confirmed before posting.
KR, Tim
Old 9th Apr 2024, 5:38 pm   #8
Edward Huggins
The motor board is fixed, but don't you get to the internals by just removing the underside board?
Edward.
Edward Huggins is offline   Reply With Quote
Old 10th Apr 2024, 8:40 am   #9
EmleyTim
EmleyTim's Avatar
You’re right of course, thanks Edward
I’d assumed it was akin to HF35/45 etc
“Must try harder” as one of my school reports read…
Tim
Reply
