Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Service Manuals, Circuit Diagrams and Data Sheets Wanted
Service Manuals, Circuit Diagrams and Data Sheets Wanted If you need help finding service data post a message here. Please do not request or offer data that is available from www.service-data.com
Reply
Old 29th Mar 2024, 6:02 pm   #1
mole42uk
mole42uk's Avatar
Default Roberts R617 help needed!
Hi, I've a Roberts FM/LW/MW/SW receiver here that has decided to be naughty. It won't switch on - I've installed a fresh set of batteries and the clock display appears, but the wireless won't respond to the red "Power/Sleep" button. I haven't been able to find any user guide or service info.
Can anyone help me switch it on?
Richard
Index:
mole42uk is offline   Reply With Quote
Old 29th Mar 2024, 6:11 pm   #2
mole42uk
mole42uk's Avatar
Default Re: Roberts R617 help needed!
Aha - I've answered my own post, it's also sold as a Sangean ATS 606 for which I've downloaded the User Manual.
Richard
Index:
Old 29th Mar 2024, 7:16 pm   #3
60 oldjohn
Hi Richard, I have a different clock that I have to short the contacts together for a few seconds to do a reset before inserting batteries. Maybe worth trying.
John.
My favourite text message "I'll be there in five minutes, if not read again"
60 oldjohn is offline   Reply With Quote
Old 29th Mar 2024, 7:22 pm   #4
paulsherwin
paulsherwin's Avatar
Roberts badged a lot of Sangean models in the 90s.
You may be able to do a factory reset - the Sangean docs you have should explain if it's possible.
paulsherwin is online now   Reply With Quote
Old 29th Mar 2024, 7:33 pm   #5
mole42uk
mole42uk's Avatar
Thanks Paul & John. I’ve put it aside for today, a little frustrated because I was hoping to use the Roberts to help align my MiniMod - but dinner is calling.
Richard
Index:
Old 29th Mar 2024, 7:46 pm   #6
granazis
I have an R700 that had the same problem. The issue was in the switch. I short-circuited the switch (as I had no idea about replacement) and it worked fine.
granazis is offline   Reply With Quote
Old 29th Mar 2024, 7:51 pm   #7
paulsherwin
This is a 90s 'world radio' and doesn't have a switch in the traditional sense. It's basically a computer.
Old 4th Apr 2024, 6:17 pm   #8
Robsradio
As Paul has said, it’s basically a computer, the power switch ‘talks’ to the CPU and tells it to switch on. It won’t be an easy fix unlike old tech, and may even be the end of the road for it sadly, but hopefully not.
Good luck.
Robsradio is offline   Reply With Quote
Old 5th Apr 2024, 7:01 am   #9
mole42uk
mole42uk's Avatar
It’s been a little temperamental - it usually switches on but I mostly have to remove the batteries to switch it off. There may be dirt on the membrane switch but the dismantling process looks a bit daunting so I need to wait for a day when I’ve time to concentrate on it. Meantime, I did use the set to align my MiniMod.
Richard
Index:
Reply
