Reply
Old 29th Dec 2021, 6:57 pm   #2641
Default Re: The Audiophoolery Thread.
To you, sir - £130. So ten pounds per amp.
I meant the wall sockets, in my opinion you can't beat a good old MK job, even the new ones which are made in Malaysia and are their standard sockets, good on them.
Old 29th Dec 2021, 8:00 pm   #2642
Philips210
https://www.futureshop.co.uk/synergi...nd-uk-13a-fuse
Note that it is a "Quantum Fuse", and so exists in a state which is uncertain until you turn something on. Then the state collapses into blown, or not.
Craig
If it was 130p it would be a rip-off. Looking at the pic of the fuse in the link, it appears to have a small crack in the upper fuse cap. Also note the horizontal grooves in the same cap showing the copper as if a pair of pliers has been near it.
With all the old cobblers specs, note it doesn't show it's been tested to BS1362 or ASTA etc!
Regards,
Symon
Philips210 is offline   Reply With Quote
Old 29th Dec 2021, 9:08 pm   #2643
Radio Wrangler
Radio Wrangler's Avatar
But they need to buy expensive fuses, plugs, cables, in order to match the expense of the rest of their systems.
Perhaps it's time I set up the Hi-End (audiphile) Power Company to sell them electricity from carefully auditioned sources. We'd send a man round to fit our classic, unsmart meter, and then return periodically to read it... all reassuringly expensive, of course. Using expensive high end power for mundane uses around the home may seem profligate, but it will improve the acoustic ambience of the place.
Radio Wrangler is online now   Reply With Quote
Old 29th Dec 2021, 9:31 pm   #2644
Philips210
Great one David!
Regards,
Symon
Old 30th Dec 2021, 11:33 am   #2645
Sinewave
Sinewave's Avatar
It doesn't bother me seeing people with nice expensive hi-fi, even if I can't afford it.
Avometer, vintage Fluke and Marconi collector. Also interested in vintage Yaesu and KW.
Sinewave is offline   Reply With Quote
Old 30th Dec 2021, 12:57 pm   #2646
knobtwiddler
If you listen to a lot of organ music, then you need wind-generated power. For Jazz, you need coal. Pop sounds best when powered from nuclear. I thought you lot would know this already! Call yourselves engineers...
knobtwiddler is offline   Reply With Quote
Old 30th Dec 2021, 1:03 pm   #2647
New Wave, tidal?
Pop, compressed gas storage.
Folk, wood fired?
Punk, anything will do.
C Rap, biodigester gas?
Old 30th Dec 2021, 1:04 pm   #2648
Martin Bush
Martin Bush's Avatar
The other day I was listening to a record sat side-on to the speakers on a stool looking at the album cover. I found that the sound changed depending on the angle I held the sleeve at.
So what would this sleeve be worth?
Is it live, or is it... no, it's live actually...
Martin Bush is offline   Reply With Quote
Old 30th Dec 2021, 4:55 pm   #2649
Valvepower
Valvepower's Avatar
Originally Posted by Radio Wrangler View Post
Perhaps it's time I set up the Hi-End (audiophile) Power Company to sell them electricity from carefully auditioned sources.
We get perfectly good sonic results using good 'ole dirty Essex electricity
Terry
Valvepower is offline   Reply With Quote
Old 30th Dec 2021, 5:22 pm   #2650
Philips210
Originally Posted by merlinmaxwell View Post
New Wave, tidal?
Folk, wood fired?
Also specifically:
The sun has got his hat on, Solar...
Regards,
Symon
Old 30th Dec 2021, 8:10 pm   #2651
Cobaltblue
Cobaltblue's Avatar
The Mods are pretty tolerant on this thread but Data protection and consumer law is well off topic so please no more.
One post deleted
Stay on Topic
Audiophoolery.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now   Reply With Quote
Old 30th Dec 2021, 8:32 pm   #2652
qtronix
reading some of this thread made me laugh.
i remember years ago i payed about 300 quid for 2x 3 meters speaker cable, think the cable cost more then the amp i was using lmao. holy crap the sound improvement was inmence. so much so i use twin earth cable now .
qtronix is offline   Reply With Quote
Old 16th Feb 2022, 9:21 pm   #2653
David G4EBT
David G4EBT's Avatar
Resistors for the discerning home-brew amplifier builder, for whom only the best will do:
'Niobium body, coupled with the excellent sonic qualities of the silver leadouts, using solid silver end caps with pure solid silver lead-out wires'.
What's not to like?
https://www.hificollective.co.uk/com...resistors.html
Goes without saying that you'll need your 'audio grade' 'hi-fi' 4.7% silver solder too:
https://www.hificollective.co.uk/com...er-solder.html
How the other half live - I am not worthy.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline   Reply With Quote
Old 16th Feb 2022, 10:00 pm   #2654
deliverance
Blimey ! Beam me up Scotty.
deliverance is offline   Reply With Quote
Old 16th Feb 2022, 10:19 pm   #2655
AKA. Plumbing solder
Old 16th Feb 2022, 10:42 pm   #2656
mark_in_manc
Wow. Including the VAT, more than 50 quid for ONE two-watt resistor. Good job they're into component-count minimalism...
"The best dBs, come in 3s" - Woody Brown
mark_in_manc is offline   Reply With Quote
Old 16th Feb 2022, 11:59 pm   #2657
Radio Wrangler
That solder is the cheap stuff. The serious stuff doesn't get advertised, so you have to ask for it (but only in the right shops): "Mithril" silver-alloy solder, made by 3M.... Moria Mining and Metals company, not the American crowd with a similar name.
Old 17th Feb 2022, 12:02 am   #2658
joebog1
I always thought you couldnt melt Mithril, unless you were a dwarf and lived in Moria??
Joe
joebog1 is offline   Reply With Quote
Old 17th Feb 2022, 12:50 am   #2659
Craig Sawyers
Craig Sawyers's Avatar
I wonder how those resistors would fare against these measurement for LIGO
https://dcc.ligo.org/public/0002/T09...rent_noise.pdf
or, from Sam Groner (Mr low distortion) https://linearaudio.net/sites/linear...lume1ltees.pdf
There are other papers regarding passive component non-linearity. But unless you try really hard (like using old carbon composition resistors), harmonic distortion in bog standard metal film resistors is down in the -120 to -140dB range.
Craig
Doomed for a certain term to walk the night
Craig Sawyers is online now   Reply With Quote
Old 17th Feb 2022, 1:21 pm   #2660
John Caswell
Could anyone please explain why E88CC "Pinched waist" or any "pinched waist" valves are now so b****y expensive.
Is it 'cos they have succumbed to the aeronautics area rule so the electrons go faster.
I despair
John
John Caswell is offline   Reply With Quote
Reply
