Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps. |
#1 |
Hello all,
Does anyone have any of the type 81 fuse lamps as used in the Hickok 539A valve tester please, or know of a supplier in the UK? It is a single contact bayonet lamp BA15S base, GE part number is GE-25736-81. Thanks Stephen |
#2 |
Morning Stephen.
The bulb that you are after is a car / truck bulb and that's all . But for years people in the USA say that if you do not use the right one the tester plays up. I am sure Lucas made one in the UK that is the same. Kev. |
#3 |
Morning Kev,
Thanks for your post, I'll keep searching! Kind regards Stephen |
#4 |
#5 |
The correct rating is important. Various sources give this as being 7 watts at either 6.5 volts or 7 volts.
Probably used as marker lights/side lights in USA. A more common rating in the UK is 5 watts. |
#6 | |
![]() Quote:
BTW, the fuse lamp glows rather brightly when testing high current rectifier valves, such as a 5U4 at inrush and glows slightly when valve is heated. Dave, USradcoll1 ![]() |
#7 |
Be sure the bulb height is the same as the one you are replacing.
I had one that was too high and would not fit properly. If you can find an older U.S. made bulb it should work OK. I bought a master box of 12 at the auto parts store for less than the price of a 2 pack on the peg board. But the glass was a bit too tall. Chinese import bulb. Also have heard of others where the bulb will not work properly due to current/ voltage differences in the import bulbs. If I had a spare, I'd send you one, but I need a couple for my own T/T for spares. Hard to find even here. |
#8 |
My list of US numbers from GE shows #81 as - #81 Bayonet Base 6.5 volts @ 1.02 amp
