Old 9th Nov 2018, 9:06 pm   #1
poya688
Post Problem to VCR Samsung SV-A80G
hello
Moving the film forward or backward moves from its place and causes difficulty
Thank you, what's the problem? please help
poya688 is offline
Old 9th Nov 2018, 10:29 pm   #2
Snarf81
Snarf81's Avatar
Default Re: Problem to VCR Samsung SV-A80G
Maybe the pinch roller is worn?
Snarf81 is offline
Old 10th Nov 2018, 12:24 am   #3
poya688
I checked I saw it was healthy
It is interesting to note that when the bar is pulled forward and the left pulley is light, the tape does not move from its place. When I pull the bar from the first and pull it back again, the tape will collect again in the middle of the tape. Mine so that I'm scared to strip the bar. This happens again when the film is running and I want to pull the tape back.
The parts that I figured out in the figure indicated that the tape would move naturally up or down so that I had to tape or run it or pull it forward to get it again. !!!!
If I need to take a picture?
Please help me find the problem.
Thank you so much
poya688 is offline
Old 10th Nov 2018, 2:36 pm   #4
poya688
hi all
This movie is also about my problem, which I also described above.
https://www.dropbox.com/s/izkpscpzh0...video.mp4?dl=0
Thnaks
poya688 is offline
Old 10th Nov 2018, 3:52 pm   #5
Snarf81
Snarf81's Avatar
Looks like the pinch roller is worn. If possible, remove it and inspect it for cracks in the rubber. If it's shiny then you need to replace it.
Snarf81 is offline
Old 10th Nov 2018, 7:12 pm   #6
poya688
I pinch roller looked, I do not seem to have a problem. The photo is attached below, I stay what I do.
https://www.dropbox.com/s/03ugpq2beoypbzf/pho1.jpg?dl=0
https://www.dropbox.com/s/g3cp2wy1pw609b0/pho2.jpg?dl=0
poya688 is offline
