Old 18th Feb 2019, 3:17 pm   #1
TALKINGWITHPYE
Location: Carrickfergus, County Antrim, Northern Ireland, UK.
Default Testing SSB transmitter with a Marconi 2955A signal generator.
Hello has anyone used a Marconi 2955a to test a SSB radio, can you use the audio generator to give two tones to inject into the transmitter.
TALKINGWITHPYE is offline
Old 18th Feb 2019, 6:09 pm   #2
kevinaston1
Default Re: Testing ssb with a marconi 2955a
The 2955a variant does have two independent audio generators, but I have never tried it on an SSB radio.
Kevin
kevinaston1 is offline
Old 18th Feb 2019, 6:13 pm   #3
Dickie
Conventional folklore (wisdom?) says that the 2955A signal generator is too noisy to be any good for SSB testing.
Regards,
Richard, BVWS member
Dickie is offline
Old 19th Feb 2019, 9:36 am   #4
TALKINGWITHPYE
Default Re: Testing SSB transmitter with a Marconi 2955A signal generator.
Thanks for your replies, I am familiar using the 2955a for fm and am but just wondered about ssb testing as I have offered a rig clinic at some local rallies. Anyway I can still test on am or fm.
