Old 7th Oct 2019, 12:49 am   #1
Terry_VK5TM
Terry_VK5TM's Avatar
Wink It's Smoke that makes it all work
Came across this yesterday that shows that it is Smoke that makes electronics work (seriously, it is in the GE Electronics Components Hobby Manual from 1965 )
(And could someone please point to the post showing how to put pictures inline instead of as attachments, my search foo is seriously failing today, thanks.)
Terry VK5TM
https://www.vk5tm.com/
Terry_VK5TM is offline
Old 7th Oct 2019, 1:02 am   #2
hannahs radios
Default Re: It's Smoke that makes it all work
That's just too funny for words terry thanks for posting
hannahs radios is offline
Old 7th Oct 2019, 1:29 am   #3
Argus25
No Longer a Member
What a great graph.
It's along the lines that the problem with electronic parts is that they have defective smoke seals, because everyone observes that when the smoke leaks out, they stop working.
I have a Heathkit robot that can talk as it contains the Votrax SC-01A speech synthesiser IC. It is pre programmed with a number of sayings, phrases and songs:
"Smoking transistors is hazardous to my health"
"I have the utmost confidence in this mission Dave"
Are just some of them.
Argus25 is offline
Old 7th Oct 2019, 7:09 am   #4
Argus25
No Longer a Member
I remember about thinking of the issue of reverse breakdown in the past because there are a number of publications explaining the severe destruction when it happens. However it isn't always. It depends on the product of voltage, current and time whether or not the junction spectacularly melts and it goes up in a puff of smoke, after all this is how Zener diodes work. You will notice though that Zener diodes over 100V are becoming difficult to get, when zenered just 100mA will cook them quickly.
There was once made a spectacular stud mounted 400V Zener, made by Lucas semiconductors, to protect the collector circuit of a transistor switching an ignition coil. They are so rare now I only have one in my collection and they never appear as a separate item for sale. Manufacturers wised up and use much less robust zeners between the collector and base of the output transistors, turning those in an active power clamp instead.
Argus25 is offline
Old 7th Oct 2019, 7:49 am   #5
Dave Moll
Dave Moll's Avatar
I'm not sure where there is a post, but it can be achieved by attaching the image as normal, then inserting into the text [attach]attachment ID[/attach]. The ID can be found by hovering over the attachment after uploading.
Dave Moll is offline
Old 7th Oct 2019, 7:53 am   #6
Nuvistor
Nuvistor's Avatar
There are instructions at the bottom of this FAQ.
https://www.vintage-radio.net/forum/...l&titlesonly=0
Frank
Nuvistor is offline
Old 7th Oct 2019, 7:56 am   #7
joebog1
Image test
That was my file name to "test" this answer.
Is this some Windows magic??
Unquote:
I dont know where you got that info from ??
Sorry, this is a genuine question.
With respect
Joe
joebog1 is offline
Old 7th Oct 2019, 8:01 am   #8
joebog1
That MUST be Windows stuff!!. I cant even get to that "position".
Soory mods
Joe
joebog1 is offline
Old 7th Oct 2019, 8:11 am   #9
Beardyman
Beardyman's Avatar
It is very illustrative of the consequences & I can see it would get the point across in a memorable way!
Here's one of my favourites if you like a bit of fun with the sometimes very dry subject of electronics. If the admins feel it is inappropriate please feel free to delete.
The difference between stupidity and genius is that genius has its limits. (Einstein)
Beardyman is offline
Old 7th Oct 2019, 8:41 am   #10
KeithsTV
KeithsTV's Avatar
In order to maintain job security, physicists strive to make electronic theory complicated. To this end, they devised a cock and bull story to do with atoms and electrons and how they were responsible for electrical behaviour.
However, in a secret document leaked from the National Physics Lavatory, it has finally been revealed that an electrical current is, in fact, a flow of smoke. This is supported by the fact that when smoke escapes from electrical equipment then that equipment seldom works any more.
Keith
KeithsTV is offline
Old 7th Oct 2019, 9:47 am   #11
G6Tanuki
G6Tanuki's Avatar
And if you break open an old-style zinc-carbon battery, it's all black inside - that's concentrated smoke!
G6Tanuki is offline
Old 7th Oct 2019, 9:58 am   #12
boxdoctor
Sometimes one even gets a bonus "fragrance" , as with Selenium rectifiers.
This is all easy tech though, compared to the theory behind Dark suckers! to which, I am sure post #8 is making a cryptic refence . Tony.
http://web.mit.edu/kolya/misc/txt/dark_suckers
boxdoctor is offline
Old 7th Oct 2019, 10:25 am   #13
kalee20
It's the sort of thing that Tektronix would have done, too. See below!
Electronics is fun, Fun, FUN!!
kalee20 is offline
Old 7th Oct 2019, 10:42 am   #14
Dave Moll
Dave Moll's Avatar
Originally Posted by joebog1 View Post
Unquote:
With respect
Joe
And with respect, it was a genuine answer based on experience.
as demonstrated above.
Old 7th Oct 2019, 10:46 am   #15
Radio Wrangler
Radio Wrangler's Avatar
Extra caution is needed. Reverse bias avalanche of a PN junction - especially a base-emitter junction can do damage even before the smoke release point. For transistors, you'll find a progressive reduction in gain and an increase in noise factor. Not as dramatic, but still worth avoiding. Maybe the smoke stays in, but gets contaminated?
Radio Wrangler is offline
Old 7th Oct 2019, 11:26 am   #16
broadgage
Semi-conductors contain magic smoke. The escape of small volumes of this magic smoke is much less noticeable than the common smoke found in motors and transformers.
broadgage is offline
Old 7th Oct 2019, 1:26 pm   #17
Terry_VK5TM
Thanks for the picture attachment replies, I'll give them a try next time (and the other replies, glad it bought a smile to the dial )
Terry VK5TM
Old 7th Oct 2019, 1:47 pm   #18
Herald1360
Herald1360's Avatar
The relevant part in this circuit is ringed below.
Smoke analysis apparently also features in some circuit simulators such as Microcap.
ID:	191468   Click image for larger version
Name:	Smoke analysis.jpg
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 7th Oct 2019, 2:48 pm   #19
julie_m
BC547s seem to be cool with this. The old Glow-Worm Combi boiler (the one that has to run the fan on half speed all the time, just to keep the pilot burner alight! How anyone can have the gall to talk about leaving a mobile phone charger plugged in .....) used to shove 24V AC almost straight into the base of one.
LEDs in cheap kettles also spend time in reverse breakdown.
julie_m is offline
Old 7th Oct 2019, 3:05 pm   #20
Argus25
No Longer a Member
One thing about this the effects are seldom seen but in two places I know of.
The audiophiles complain that in their amplifiers with BJT based IC's, with coupling capacitors between stages, that sometimes with power cycling the IC's get degraded over time as from time to time the B-E junctions of the input devices in the IC get degraded. Sometime they recommend replacing all the IC's in an amp for this reason. I have never been able to hear the effect of this myself.
The other example that happens is in the simple common 2 transistor multivibrator circuit. If it is powered by more than 7V the B-E junctions Zener on each half cycle , it's easy to see on a scope on the capacitor's charging waveform at the base of the transistor. This does relentlessly damage the transistor and after some time the multivibrator will not start as the transistor's hfe gets progressively lower. This is an effect I have seen in an instrument.
Motorola wrote a paper on the effect of hfe degradation of transistors after zenering their B-E junctions, as I recall the exact mechanism of it remained speculative.
I think there is an application for it though. If two transistors require an exactly matched hfe, the one with the higher hfe could be treated with some pulses of breakdown to lower it until it exactly matched the other transistor.
Of course it doesn't matter if an LED or some diode gets zenered, as long as the dissipation is low, because there is no hfe issue to contend with. The big evil of it is for a power supply rectifier because the circuit impedances are low, the breakdown voltages are high and the reverse breakdown currents are high, so the device goes boom when a voltage spike comes along and its piv gets exceeded.
Argus25 is offline
