13th Feb 2015, 9:24 pm | #1 | |
BA and other threads etc
Also, only the 0BA and M6 are nearly the same, other sizes don't match up.
14th Feb 2015, 5:12 am | #2 |
Re: BA and other threads etc
BA threads are indeed specified in metric dimensions, but I suspect the nuts were made from hexagonal bar stock with imperial (outside) dimensions, though I may well be wrong. However, I can't recall where, but I read that some current production BA nuts are made from standard metric hexagonal stock because the original sizes are no longer available.
14th Feb 2015, 7:59 am | #3 |
Hi Gents, a look at Engineers or Machinery Handbooks(or a good Google) will reveal the vast array of thread types that are available, together with a their principal dimensions as well as the relationships between these dimensions and also the relationships to other sizes in the same series.
Ed |
14th Feb 2015, 8:45 am | #4 |
Lots of thread information is at:
http://www.alanstepney.info/page8.html |
14th Feb 2015, 2:37 pm | #5 |
Thanks Alan. Great info there. now in my fav file
Should get out more. Regards Wendy G8BZY |
14th Feb 2015, 3:25 pm | #6 |
There's some, probably accidental, compatibility between BA and ISO threads in that a metric screw will go in a BA hole but a BA screw won't go in a metric hole.
- Joe |
14th Feb 2015, 3:59 pm | #7 | |
Cheers, GJ
http://www.ampregen.com |
14th Feb 2015, 5:46 pm | #8 |
BA is actually a metric system as it is based upon the Swiss Thury thread. All the British Association did, when they copied the Thury thread, was to specify it in Imperial dimensions.
The major difference between Thury / BA and todays metric threads is that the latter has a 60 degree thread angle and "sharp" (as opposed to rounded) peak and trough. |
15th Feb 2015, 1:19 am | #9 |
Sorry, but BA screws have always been specified in metric (mm) dimensions. Although, except for 0BA (6mm dia) the sizes aren't a round number.
The next size is found by multiplying by approx. 0.9, so 1BA is 5.4mm dia, 2BA is 4.8mm dia, etc, which is a good system - similar to preferred resistor values. The thread angle is 47.5 degrees, so although a 0BA and M6 screw have the same diameter (and the same thread pitch, as well), putting an M6 nut on a 0BA screw, or vice versa, isn't good practice. |
15th Feb 2015, 10:13 am | #10 |
If I recall correctly, one advantage of BA was that the drill size down from clearance was the correct size for tapping the smaller thread.
15th Feb 2015, 11:21 am | #11 |
Yes, BA threads were designed according to a mathematical progression so that each fastener's clearance drill was the tapping drill for the next size up, and without regard for round figures either in millimetres or in inches.
15th Feb 2015, 11:26 pm | #12 |
Absolutely - the only round figures are 6mm diameter, 1mm pitch, for the 0BA... and for the others the round figure is the BA number!
