Old 7th Nov 2017, 7:08 pm   #1
PaulW7668
Default Gamages Radio
I have in my possession a valve radio with the Gamages logo on the scale plate. There is no other markings on the case or chassis to identify this radio. The valve lineup is 7S7 Frequency Changer, 7B7 IF Pentode, EBC33 Audio Triode, 7C5 Audio Output and 7Y4 Rectifier. The set is a 3 band LW, MW and Shortwave.
By the valve lineup I would suggest a date around 1950. Can anybody help with further information, since searching the Internet only gives details of radio equipment prior to WW2.
PaulW7668 is offline
Old 7th Nov 2017, 8:22 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: Gamages Radio
Gamages was a large department store in London. An uncle of mine used to send me Gamages branded recording tape as birthday presents.
https://en.wikipedia.org/wiki/Gamages
paulsherwin is offline
Old 7th Nov 2017, 8:23 pm   #3
There were loads of 'no-name' radios built by small outfits to serve the needs of the chain-stores of the time.
Trying to positively identify the maker and get a circuit/schematic can be a hell of a task: often the same outer-case [produced by a 'jobbing' cabinet-maker business] could house one of a number of different radio-chassis, sourced from similar 'jobbing' radio-businesses.
If you're lucky you may find that the radio was made by one of the bigger producers, such as Plessey.
Can you post some photos in the hope someone may recognise what you've got?
Old 8th Nov 2017, 10:38 am   #4
Thread moved to correct section. Some posts deleted as no longer needed.
Station X is offline
Old 10th Nov 2017, 8:03 pm   #5
PaulW7668
Attached are views of this radio, perhaps somebody will recognise this radio.
ID:	152062   Click image for larger version
ID:	152063   Click image for larger version
ID:	152064   Click image for larger version
Old 10th Nov 2017, 10:47 pm   #6
paulsherwin
Many radios of this type were made by small manufacturers in the late 40s, often set up by engineers who'd learned their trade in radio and radar during the war. They often used whatever components were available cheaply on the surplus market, and the odd mixture of octal and B8B Loctal valves is typical. My guess would be that Gamages signed an agreement with some man-in-a-shed operation in Croydon or wherever to make these radios for them. The cabinets may have come from an additional furniture manufacturer.
The circuit is likely to be a standard 4 valve L/M/S superhet plus a rectifier.
Old 10th Nov 2017, 11:40 pm   #7
peter_sol
It looks like a standard chassis made by Plessey as used by Regentone
peter_sol is offline
Old 10th Nov 2017, 11:48 pm   #8
camtechman
camtechman's Avatar
To me, the tuning scale seems to be "Bush" in style.
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it!
camtechman is offline
Old 11th Nov 2017, 12:30 am   #9
AC/HL
AC/HL's Avatar
It looks like it was made by Strad, the nearest chassis on RM is the 553W.
AC/HL is offline
Old 11th Nov 2017, 8:15 am   #10
Neil Purling
Is the power transformer possibly a replacement item? Made by Elstone.
Neil Purling is offline
Old 11th Nov 2017, 9:13 am   #11
The knobs look the same as those used on the Strad 511 (RM Electric)
Old 11th Nov 2017, 9:56 am   #12
Boater Sam
Black Magic coffee cream knobs. Strad for sure unless they were a generic knob.
The chassis shape with the corners of the back plane cut back is very familiar too.
I was trying to recognise the IF transformers, but failed.
Boater Sam is offline
Old 11th Nov 2017, 10:25 am   #13
Here's an ad for RM Electric's IF transformers....they look familiar:
http://www.americanradiohistory.com/...df#search=%22r m electric%22
Old 11th Nov 2017, 12:20 pm   #14
paulsherwin
Why the EBC33 though? (Unless it's a later replacement with a socket change).
Old 11th Nov 2017, 12:38 pm   #15
Looking at the chassis photo it looks like EBC33 either printed or written on the chassis, nothing conclusive from that photo though to suggest that the EBC33 was originally fitted.
Old 11th Nov 2017, 12:49 pm   #16
Edward Huggins
I would not think this uses a Plessey chassis as it has an R&A speaker.
Edward.
Edward Huggins is offline
Old 11th Nov 2017, 1:10 pm   #17
On second thoughts the valve holder rivets look undisturbed?
Old 11th Nov 2017, 1:52 pm   #18
Andrewausfa
Andrewausfa's Avatar
RM Electric made sets for other brands like 'Rolland' so could have made this. The cut corners of the chassis is also seen on RM sets.
Has your speaker baffle board got a bad case of woodworm?
Andrew
Invisible airwaves crackle with life. Or they should do.
BVWS Member
Andrewausfa is offline
Old 11th Nov 2017, 2:14 pm   #19
HamishBoxer
HamishBoxer's Avatar
Marconi I think??
HamishBoxer is offline
Old 11th Nov 2017, 5:04 pm   #20
michamoo
michamoo's Avatar
The use of a R&A speaker makes me think of Pye maybe?
If smoking is so bad for you, how come it cures kippers?
michamoo is offline
