25th Jun 2016, 10:09 am | #1 |
Tandberg CTV 1
I just got an old Tandberg. According to the people I got it from it was used to about year 2000. When I was in the trade (early 90's) I only saw two or three of these. At the time I didn't like them.
This set was working when it was used last. I had a brief look into the set. It looked dusty, but everything was original and there was no signs of heavy use. I plugged it in and was awarded with sound, and after about a minute the picture was there. It filled the whole screen. But then the smoke came. There was a lot of it. It smelled burned paper. I guess it was a RIFA, but I couldn't see the damage. I have to do a closer inspection to find the culprit. I have had a look on the net for the diagram for this set, but none of the usual places has it. Does anyone on the forum have it? |
25th Jun 2016, 10:19 am | #2 |
Re: Tandberg CTV 1
That's the one with a spring-loaded resistor by the LOP stage that deliberately hits the metal frame and blows the fuse when it opens if I rememeber rightly.
It sounds a nice project. I only saw a couple of these - they were imported in the early Seventies, but there were nowhere near as many as the CTV2. Television magazine did an article on them in the late Seventies but I don't have the date unfortunately, though I'm sure an archivist here will be able to find and scan it for you. Glyn |
25th Jun 2016, 10:53 am | #3 |
Re: Tandberg CTV 1
We didn't have colour broadcast here when these were made. They didn't sell many of these here. I guess you had to be very interested in TV to fork out all the money for a set like this when most of what you cold use it for was B/W. The CTV2-4 was made in the UK.
27th Jun 2016, 7:46 pm | #4 |
Re: Tandberg CTV 1
Here's the Television article July 1977 issue. Covers the Line and Field timebases and the PSU.
Keith |
27th Jun 2016, 7:59 pm | #5 |
Re: Tandberg CTV 1
Hello,
Interesting set, using 3 x PL802 pentode valves for the RGB drive to the CRT. I had one in the past but moved it on all in order to concentrate on UK made TVs. Regards, Dazzle vision |
27th Jun 2016, 11:31 pm | #6 |
Re: Tandberg CTV 1
28th Jun 2016, 3:10 pm | #7 |
Re: Tandberg CTV 1
I couldn't remember which set used the three PL802s - I'd thought it was a Skantic or Luxor but found out I was wrong. Thanks for the information!
Glyn |
28th Jun 2016, 3:28 pm | #8 |
Re: Tandberg CTV 1
Luxor used 3 x EF184,Malc.
Malc Scott |
28th Jun 2016, 3:53 pm | #9 |
Re: Tandberg CTV 1
As to be expected, watch out for heat damage on the printed circuit from the PL802's.
When it became difficult to obtain the PL802, a solid state version was produced. Also the line osc. ECH84 was prone to o/c heaters, caused by flashover in the PY500. |
28th Jun 2016, 6:40 pm | #10 | |
Re: Tandberg CTV 1
Much info there that'll come in handy. They don't have for colour. I could only find for mono sets. |
28th Jun 2016, 7:10 pm | #11 | |
Re: Tandberg CTV 1
I had a good look at the set again. All the smoke had to come from somewhere. I had a look at the Rifas in the "power supply", but the all looked unburned. All of them have a few small cracks. Not deep and wide cracks like in my Tandberg TV1 which is ten years older and have lived 10+ years in a damp garage. All the other components looked well too.
I then wanted to try a more efficient method: I plugged the set and turned it on keeping a finger on the power switch for fast depowerment. This time there was no smoke.... The next step will be to find a signal source. I would like to see if this old tube will give a good picture. Quote:
This set has no heat damage that I can find. Some resoldering has been done one the valve bases. I have to do some resoldering on other places, but this set looks little used. 20+ years ago I scrapped a CTV 1. That set had the solid state PL802s. I have them somewhere. |
29th Jun 2016, 10:29 am | #12 |
No Longer a Member
Re: Tandberg CTV 1
PM sent regarding service manual.
