11th Aug 2019, 12:53 pm | #1 |
John Fluke thermometer + printer, problem
hello friends,
I am asking if one of you is familiar with the fluke thermometer set: 2190A thermometer 2030A the little printer 2300A the thermocouple scanner. My problem: the printer dont want to print. Description in detail. I have: Fluke 2190A with option 6 = limits, no option 2 = output, Manual = yes Fluke 2300A thermocouple scanner with a card 002 (can listen 10 probes), Manual = no Fluke 2030A printer (there are no options, always the same) Manual = yes In the 2190A specs is written a 2190A requires option 2 = output, to be directly conected to the printer, unless a 2300A thermocouple scanner is used. This is used bec. I have no opt.2 in the thermometer.. setup. 2190A connected to the 2300A, ok 2300A connected to the 2030A printer, ok. temperature reading: ok scanning: works, ok. The printer have a print button, but this will not start a printing. S i think I made any mistake or there must be a setup, device code or anything like that, I am asking for help. I simply need a printing thermometer with one probe, the 2300A is here only used as a useful interface from the thermometer to the printer. greetings Martin
www.wellenkino.de Vintage Scope restorations |
