6th Aug 2019, 9:51 pm | #1 |
Weller TCP Plug Connections
Hello, I have a used Weller TCP iron without a 3 pin plug - it has 4mm plugs on the end of the cable.
I want to fit a Bulgin 3 pin plug on the end of the cable instead of the 4mm plugs - it's for a friend to use with a different transformer. Could anyone let me know what the Bulgin plug connections are, as I don't currently have the transformer to check? I guess it's just a question of which pin is earth. Many thanks! Lance |
7th Aug 2019, 1:37 am | #2 |
Re: Weller TCP Plug Connections
There is nothing special as long as it is a regular TCP iron with a magnetic thermostat.
The stations are wired with an earth on the pin opposite the notch and the other two pins are 24 volts AC and can be connected either way around. |
7th Aug 2019, 1:35 pm | #3 |
Many thanks - that's exactly the info I needed!
Lance |
8th Aug 2019, 8:14 am | #4 |
Hi there,
possibly of use to you and others. Weller TCP User Guide with circuit. rgds to all. |
10th Aug 2019, 9:45 am | #5 |
Great - thank you!
Lance |
