24th Aug 2018, 5:50 pm | #1 |
Bush VHF81 Heat Deflector
Hello,
I’ve just been dismantling my VHF81 and the service sheet says ‘slide the Presspahn heat deflector outwards from the top inside of the cabinet’ but there isn’t one instead there’s a foam pad glued to the top. I’ve looked at photos on the net but can’t see any others like this so is this original or a later modification, anyone seen this before? Does anyone know what this is made of, it is like a fine cotton wool, is it likely to be anything nasty like asbestos? Thanks for looking. John Last edited by stitch1; 24th Aug 2018 at 6:15 pm. Reason: Typo |
24th Aug 2018, 5:59 pm | #2 |
Re: Bush VHF81 Heat Deflector
Form? What are the forms for, ordering pizzas?
Sorry, realise its a typo, couldn't resist. What sort of foam, colour, texture? Original or added? Could it be the asbestos substitute that someone has fitted? I have some black foam that is used in prison mattresses and is totally fireproof and insulating, I mean like blowlamp proof. Never seen any foam in any '81 I've had in. |
24th Aug 2018, 6:09 pm | #3 |
The Presspahn company still seem to exist (in Bradford) making various paper based products. I wondered if there was originally a layer of foil on top of that pad (foil to reflect the heat/pad to insulate)?
24th Aug 2018, 6:14 pm | #4 |
Yes a typo, and somehow I managed to post it twice!
It’s white (or was), texture like cotton wool but finer. I can’t say if it’s original or not but it seems original and the radio doesn’t appear to have ever been repaired in any way. John |
24th Aug 2018, 6:22 pm | #5 |
Could it be fibreglass?
Frank |
24th Aug 2018, 6:38 pm | #6 | |
Yes I think it could be. John |
24th Aug 2018, 6:50 pm | #7 |
It looks like fibreglass to me.
24th Aug 2018, 7:27 pm | #8 |
So probably fibreglass, may not be original ... any issues with this or just leave it in?
John |
24th Aug 2018, 7:41 pm | #9 | |
Presspahn We are a privately owned business that was founded in 1925 as specialists in the supply of paper insulation used in the manufacture of power transformers. John |
24th Aug 2018, 8:04 pm | #10 |
hello all you have a part missing !!. bellow the felt is/was a heat resistant board 14" long 3.5" wide with 90deg lip,it fits under the felt above the ferrite rod ,the lip is curved the held in with the screws that hold the back on
its a pig to get back in |
24th Aug 2018, 8:19 pm | #11 |
Thanks Dave, I’ve seen a picture on the net showing this in situ. I could look for an alternative or maybe I’ll try this https://secure.presspahn.com/Cart/in...2g8li0aihgugg0 cheap enough and no min order but unfortunately £7.20 postage.
John |
24th Aug 2018, 8:32 pm | #12 |
hello all, yes that's the stuff, mine does not get very hot, so poss a different heat resistant sheet ?. £7.50 a bit much for a cheap product
dave |
24th Aug 2018, 8:40 pm | #13 |
My VHF81 has the white fibrous pad as shown, but there's no kind of shield or anything over it.
The top of the case doesn't get hot to any sort of extent that would cause me concern, even when the radio's on for 10 hours at a time. |
24th Aug 2018, 8:50 pm | #14 | |
dave |
24th Aug 2018, 8:56 pm | #15 | |
That's interesting, so it could be original perhaps on a later version, unfortunately there's no sign of a date anywhere. It's not clear from the photo on RMorg if there's a pad and card but if others have both then it's likely to be missing. John |
24th Aug 2018, 9:01 pm | #16 |
There's one on eBay at the moment and it just has the pad but it's smaller and not even above the dropper, which perhaps suggests the card is missing.
John |
25th Aug 2018, 8:56 am | #17 |
Is this the part in question? On my set there is a small fibre glass type pad and what I assume is the heat deflector slides underneath and is held in position by the screws securing the back.
Although the set has 7 valves it doesn't seem to run unduly hot, possibly because the dropper has less to do with more valves in the chain?? (compared with say a DAC90A)
Howard |
25th Aug 2018, 9:20 am | #18 |
Hi Howard, yes that's it, thanks for the pics I can see how it fits over the chassis now.
As you say it doesn't run very hot but I may see if I can get some Presspahn (or a cheaper alternative) I'll drop them an email and see if they have any cheap off cuts John |
25th Aug 2018, 10:28 am | #19 |
Hi John
That sounds like a plan, a small piece would do. Good luck with it!
Howard |
25th Aug 2018, 2:02 pm | #20 |
The valve heaters and dropper together will still be dissipating 230V * 0.1A = 23W, so a set with 7 valves will be putting out exactly the same amount of heat as a set with just 4 or 5 valves. What has changed is the dispostion in space of the heat sources. A set with FM and a tuning indicator of additional RF stage will be emitting heat in eight different places (seven valves and the dropper) versus the usual six (or five if a UCL8_ is used instead of a UBC% and a UL%). The improved distrubution of heat dissipation means individual components will run cooler, but the exhaust air will have the same temperature. Slightly higher if anything, thanks to the anode dissipations of the additional valves; but this is negligible compared to the UY% and the UL% valves, which are responsible for the lion's share of this contribution to cabinet heating.
