Old 29th May 2020, 7:15 pm   #1
coopzone
coopzone's Avatar
Default Ultra T401 AGC question
Hello,
I've been renovating an Ultra T401 chassis for a couple of weeks. It's now working ok. But it does not seem very sensitive, it's probably my 10 ft of copper wire test aerial.
However when i was investigating a little i decided to see what the AGC circuit was doing (on the general principle of - it could be ..). So i have observed it does not seem to change in value a great deal - is this normal?
I don't live near any strong local stations, in fact reception is generally quite poor anyway. So my real question is what sort of values should i read on the AGC voltage, at the moment it is around -0.75v, but hardly changes between the best signal radio 4 and no signal (static).
measurements taken with a high impedance (10mega ohm) DVM meter, so although it will have some effect on the voltage it will be far less than an AVO type meter.
Derek
coopzone is offline
Old 29th May 2020, 9:08 pm   #2
FERNSEH
FERNSEH's Avatar
Default Re: Ultra T401 AGC question
The Ultra T401 has a delayed AGC system. The negative delay potential is developed across R12 (47ohms). This resistor can go high value. Check the cathode bias resistors of the PEN45DD output valve. R6 180ohms and R14 390ohms. Also elcos C33 and C37 (50 and 100microfarads).
DFWB.
FERNSEH is offline
Old 29th May 2020, 9:32 pm   #3
cathoderay57
Re-Alignment, particularly the final IF transformer, can make a big difference to signal level at the detector and consequently AGC voltage. Cheers, Jerry
cathoderay57 is offline
Old 30th May 2020, 9:56 am   #4
coopzone
coopzone's Avatar
thanks
Checked the resistors and caps, replaced as needed.
I'll have a go at realigning it next. It has those brass adjusters on the IFT's, way too easy to break them! These are sealed with varnish, I'll do my normal trick and heat with a soldering iron first this time!
Derek
coopzone is offline
