28th May 2020, 5:19 pm | #1 |
Electrolytic Can Capacitor Replacement Good Practice
I have searched around for information/photos of under the chassis electrolytic capacitor replacement but not found anything that I would be happy with.
Does anyone have a link to a website or pictures of how they have replaced axial and radial capacitors under the chassis. Thank you. |
28th May 2020, 6:21 pm | #2 |
Re: Electrolytic Can Capacitor Replacement Good Practice
If I am concerned about the aesthetic look of a replacement, my instinct is not to replace it, but to re stuff the original can.
What type and era of equipment do you have in mind?
-- Graham. G3ZVT |
28th May 2020, 6:34 pm | #3 |
Hiya, I wasn't thinking of removing the can but installing the capacitors under the chassis.
It is a Bush PB. 12. |
28th May 2020, 9:21 pm | #4 |
Looks easy enough, plenty of room for modern 400v capacitors.
Use the tag board for the +ve side of the caps, (R23) and the -ve sides to a suitable earth point, perhaps the common on the original cap. Do disconnect both +ve connections on the original, it would indeed be bad practice not to do so. Are you sure you don't want to re stuff the can, it's fun.
-- Graham. G3ZVT |
28th May 2020, 9:31 pm | #5 |
Thanks Graham, just the info I was looking for.
I have a few radios that I am working on, so maybe will try stuffing the can on my next one as keen to get this one up and running. Brian |
