Old 8th Apr 2020, 8:24 pm   #1
kestrelmusic
kestrelmusic's Avatar
Default Ultrasonic cleaning
I saw a video on Youtube the other day in which someone restoring a vintage radio used an ultrasonic cleaning bath to de-grime various parts including a tuning gang.
Has anyone had experience in using one of these? They are obtainable quite cheaply. But I don't want to either buy something I will only use once or twice, or something that could damage fragile components. I dread to think of something that could reduce "monkey metal" parts to a heap of sludge!
kestrelmusic is offline
Old 8th Apr 2020, 10:05 pm   #2
David G4EBT
David G4EBT's Avatar
Default Re: Ultrasonic cleaning
This topic crops up from time to time.
Rather than go over old ground, this thread might be of interest:
https://www.vintage-radio.net/forum/...asonic+cleaner
The conundrum is that whilst they’re invaluable when needed, for many, the limited use doesn’t warrant the expenditure on a really effective bath. My own experience is that as with most things, you get what you pay for. The bath needs to oscillate at sufficiently high amplitude to be truly effective. I tried two cheap ones with disappointing results, which went back for a full refund before I bought an effective one. That said, others claim good results with cheap ones, but I doubt they would have a tank large enough for a two-gang tuning capacitor.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
Old 8th Apr 2020, 10:09 pm   #3
Bazz4CQJ
Bazz4CQJ's Avatar
I think there was a lengthy thread within the last six months on this.
Those cleaners are wonderful if you get a good one, but much caution required if buying the budget ones.
B
Bazz4CQJ is offline
Old 9th Apr 2020, 4:34 pm   #4
usradcoll1
B
A few of the budget ones are nothing but an AC buzzer mounted on the bottom of a small vessel. They sell them as a jewelry cleaner. Totally worthless!
I was lucky to get a small one at a charity shop, a real one that works well for small items. It also has a digital timer that can be set for several minutes or so. I used it to clean a ball bearing for a project.
usradcoll1 is offline
Old 14th Apr 2020, 1:58 am   #5
retailer
Take a look at this
https://www.youtube.com/watch?v=R1DtY2VwSyY
retailer is online now
Old 14th Apr 2020, 3:50 am   #6
Bazz4CQJ
Bazz4CQJ's Avatar
That's really interesting! I doubt if it competes with a professional grade ultrasonic cleaner for really critical processing (aerospace/defence), but for DIY, it very probably beats many of the "budget ultrasonic cleaners".
Also useful for when a part is too big for an ultrasonic bath.
B
Bazz4CQJ is offline
