23rd Oct 2006, 8:04 pm | #1 |
Where do you start?
I don't know how other restorers work, but I always start the electronics first - on the basis that if I can't get that going there is no point doing the box!
Where do others start?
The older I get, the faster I was! |
23rd Oct 2006, 8:26 pm | #2 |
Re: Where do you start?
Making it clean, because I have to see (and in some instances smell ) the thing. All else can wait a decade or two if need be, and often has...
Paul |
23rd Oct 2006, 8:38 pm | #3 |
Yes, vacuum off the dust from the chassis, clean the bottles, have a look underneath and replace anything obviously dead or suspect, then power it up slowly on a variac and sniff!
23rd Oct 2006, 8:45 pm | #4 |
I agree Andy, I always get the electronics going first, but certainly clean the chassis to a reasonable degree - Why restore the case of a TV to later find you have a duff LOP transformer or tube that might make the project unviable? I guess it's a little diffent with radios, as you don't often get such "show stoppers" - I still like to get the thing working first thought. Somehow it's like taking things for granted polishing up the case first
Chris Last edited by mikelect; 23rd Oct 2006 at 9:00 pm. Reason: shouting |
23rd Oct 2006, 8:50 pm | #5 |
Oh, the whole of what's inside sometimes waits the full decade or two here, if the dust is the nice sort. Nice dust doesn't smell when it's cold I've not had a variac in service yet, so when the time comes it's a case of reforming the main electrolytics with my trusty Hunts bridge, checking for shorts on the HT line, then switching on and standing well back
I take a pretty relaxed attitude toward the possibility of things actually working. When you've 700-odd radios around but don't listen much to the radio, and a couple of dozen TVs but never watch, it doesn't seem to matter much if half of them aren't in a fit state to do anything ... Paul |
24th Oct 2006, 8:21 am | #6 |
I start with taking the chassis out of the cabinet (or I some-times start by taking the back panel off although I think most people do this first ). I give the chassis a clean then I check all the resistors and capacitors before I then power it up. Once it is working well I clean and polish the cabinet. Some-times I will polish a cabinet halfway through a chassis restoration- it is very theraputic if the thing still isn't working! My Wartime Civvy is very shiney now... Josh.
24th Oct 2006, 10:39 pm | #7 |
I usually do a quick check of the mains and test the mains transformer and o/p tx just in case they are dud and may make the set non viable. I usually do the electronics first( I find it easier than cabinets) but have been known to chicken out and take "empty" woodies along to a local furniture restorer!
25th Oct 2006, 8:19 pm | #8 |
Since I usually deal with portables--first order of the day is a complete teardown of the cabinet, chassis and hardware removed. Then I go over the case with GoJo hand cleaner, let it sit for a minute to dissolve the dirt and grime, then rinse off. If it's a plastic cabinet, both it and the knobs get a good rubdown with plastic polish. After that, it's on to the electronics. When I reassemble the set, repaired or not, it'll at least be shiny, clean and presentable. That's important if you have a wife who believes in cleanliness above all else....
Bill |
26th Oct 2006, 11:57 am | #9 |
Like most restorers, I want to see if there's anything worth restoring before I put too much time and effort in, so first checks are made on HT and input circuitry, looking for shorts or opens (in the case of transformers). A clean reading here and the set is powered via the test lamp. Encouraging signs here, i.e. no smell of burning, no brilliantly lit lamp) leads to a clean-up of the chassis and fault correction. Once the chassis is functioning well, the cabinet can be looked at.
That's my general approach. -Tony |
26th Oct 2006, 12:43 pm | #10 |
I tend to do things in reverse... Since the cabinet has to be tackled more slowly than the insides, with say a couple of flatted coats laid down every day, I'll start with the cabinet, then follow on later with the electronics, often doing this alongside.
Then, once the set is finished, I'll finish with the cabinet too, since further flatting is often necessary days later to deal with grain pits which have emerged etc. Steve |
27th Oct 2006, 6:03 pm | #11 |
Hello,
I don't start restoring a set until I feel certain that I can complete it, so if any bits are missing or are irreparably damaged, then I will hunt down and acquire those first. When I have all the bits, then restoration begins, and I usually restore the case first, by totally dismantling it, cleaning it thoroughly, repairing it and then reassembling it. The chassis comes second, and as I usually restore transistor sets they are usually in some sort of working order except for sets with AF11* transistors in them which I generally replace. If a set sounds distorted or is dead on one or more wavebands then I seek assistance. Howard |
