9th Oct 2006, 10:48 am | #1 |
Daft Marconi transistor radio
I've attached a couple of photos of a radio (don't know the model) that I picked up at a car boot sale the other day. Quite simply, can anybody explain why the speaker is mounted on the back of the radio! If I stand it against a wall it sounds awfull!... Mind you it doesn't sound much better when I don't Thanks David |
9th Oct 2006, 10:53 am | #2 |
Re: Daft Marconi transistor radio
Perhaps it's meant to be used laying flat with the handle folded underneath and the speaker at the top?
9th Oct 2006, 10:56 am | #3 | |
A long time ago I used to have a somewhat similar Marconi set, though MW/LW only. It worked fine when placed on the parcel shelf under the dashboard in my dad's car and the car aerial connected - I always assumed the speaker was on the back as it was meant as a car/portable set. Quote:
Regards, Kat |
9th Oct 2006, 11:12 am | #4 | |
Another daft thing is an aerial socket in the bottom (see photo) which cannot be used when standing upright Maybe Kat is onto something with the car idea! David |
9th Oct 2006, 11:45 am | #5 | |
Paul |
9th Oct 2006, 1:50 pm | #6 |
Well speakers in the back were good enough for B&O!
David, if you tightened up the handle, would it not stay put in a vertical plane and support the set at a bit of an angle? But then the "front" of the set is far too attractive to be hidden underneath it in any case. Strange indeed.
John. |
9th Oct 2006, 2:12 pm | #7 |
The bolts for the handle have shoulders which prevent me tightening the grip on it. The only resistance is from a couple of, very flimsy, dished spring washers.
I keep looking at it but I really can't see how this radio can be stood, apart from the usual upright position |
