Reply
Old 20th Feb 2024, 2:37 pm   #1
lloydwells
Default Frame blocking VDR problem.
OK so I'm currently working on a Danish made Always Herkules TV2361 it's a 23" set using a 110° tube the TV works however it has an audible ticking I've got this down to being something around the frame output transformer or frame blocking transformer this tv uses Early 1960s transformers and deflection unit by Philips see attached pictures. The diagram shows a Philips VDR part number VD9010 and a 1.2K 1 watt resistor across the primary of the frame blocking transformer this had had another incorrect VDR bodged in at some point and it's dead. I cannot find any info to help work out a replacement for this Philips VD9010 and sort this ticking i would point out that pin 5 and 6 of the Pcl82 feeding the transformer were arcing across the valve base I replaced the base same old ticking. Any help gratefully recieved.
ID:	293279   Click image for larger version
ID:	293280   Click image for larger version
lloydwells is offline   Reply With Quote
Old 20th Feb 2024, 4:08 pm   #2
dazzlevision
Default Re: Frame blocking Vdr problem
The VDR you refer to is connected across the primary of the frame output transformer.
In the 1960s, a commonly used Philips/Mullard VDR in the UK across the primary of the frame output transformer was type E298ED/A258. This was a rod type VDR with axial leads and a green marking at one end. There was no series resistor.
The frame output valve was invariably a PCL85/PCL805.
If you are unable to find a good VD9010, this one might be worth a try.
dazzlevision is offline   Reply With Quote
Old 21st Feb 2024, 2:30 am   #3
Maarten
Default Re: Frame blocking VDR problem.
Unfortunately I can't read the datasheet. 2 back to back zenerdiodes of the right voltage might work.
Maarten is offline   Reply With Quote
Old 21st Feb 2024, 11:59 am   #4
Marconi_MPT4
Marconi_MPT4's Avatar
Very brief data from book, Philips Components For Radio TV and Audio 1960, page 27.
Looks as if VD 9010 is characterised by passing 60 to 120uA at 100V. No information on the delta change for higher voltage. Maximum power dissipation is 0.5W for disc type and working temperature 150°C max.
More detailed information might be found on data sheet EP1526.
Rich
Name:	Screenshot from 2024-02-21 10-14-22edit.jpg
To an optimist a glass is half full; a pessimist half empty; an engineer twice as big as need be!
Marconi_MPT4 is offline   Reply With Quote
Old 21st Feb 2024, 4:16 pm   #5
Welsh Anorak
Welsh Anorak's Avatar
Not something I know anything about I have to admit, but this was in my drawer of themistors/VDrs. Is it what you're talking about?
Glyn
www.gdelectronics.wales
Welsh Anorak is offline   Reply With Quote
Old 21st Feb 2024, 4:27 pm   #6
dazzlevision
Yes, that’s the one used in UK made sets of the 1960s or its PCB equivalent.
Old 21st Feb 2024, 4:36 pm   #7
FERNSEH
FERNSEH's Avatar
The function of the VDR across the primary of the output transformer is to partially suppress the positive going flyback pulse, but not too much as to impair the frame retrace characteristic. Removal of the VDR might cause damage to the transformer.
The energy of the flyback part of the scanning waveform must be same as the forward scanning part.
A diode clamp might be a possible solution. Clip the peak value of the flyback pulse.
DFWB.
FERNSEH is offline   Reply With Quote
Old 21st Feb 2024, 5:28 pm   #8
Maarten
Closest to original, would be a back-to-back zener diode clamp, or a bidirectional transil. Maybe 120V 5W? Just guessing from the few data we have.
Old 21st Feb 2024, 5:48 pm   #9
FERNSEH
FERNSEH's Avatar
From the Pye 169 manual.
The sawtooth waveform at the anode of the pentode section of the PCL85.
Note the amplitude of the flyback pulse, 700volts and that's with a VDR across the primary of the transformer.
The Herkules TV2361 under discussion has a 110degree deflection system so it's likely the waveform will be similar to that shown in the attachment.
DFWB.
Old 21st Feb 2024, 6:16 pm   #10
Welsh Anorak
If the VDR in post #5 is any use to the OP it's yours FOC. PM me if you'd like it.
Glyn
Old 22nd Feb 2024, 10:04 am   #11
lloydwells
Welsh anorak I've actually found some for sale 10 for £4 seemed cheap enough but thanks for the offer.
Reply
