Reply
Old 12th Feb 2024, 5:33 pm   #1
HamishBoxer
HamishBoxer's Avatar
Default Ekco TC267/1 No Raster
This is a real pain and rarely I get stuck, totally blank screen EHT normal. Problem is, I cannot get cabinet and chassis on the bench.
A while ago, some kind person put out a list of faults for this chassis, where now I do not know.
Yes it gives the centre spot when turned off and that is it.
Any thoughts? Ion trap is well locked I add.
Thank you.
HamishBoxer is offline   Reply With Quote
Old 12th Feb 2024, 9:24 pm   #2
FERNSEH
FERNSEH's Avatar
Default Re: Ekco TC267/1 No Raster
Ekco TC267/1. That's the later version which employs 0.3amp valves.
Is the CRT grid voltage higher than the cathode voltage? The Mazda CRM172 grid to cathode voltage is -30V to -70V for cut-off.
First anode voltage should be 300V relative to the cathode.
Try shorting the CRT grid and cathode together.
DFWB.
FERNSEH is offline   Reply With Quote
Old 12th Feb 2024, 9:34 pm   #3
Freya
Freya's Avatar
I have the genuine ekco sheets for this including the addendum pages. PM me if you need them.
Stephen
Freya is online now   Reply With Quote
Old 13th Feb 2024, 11:00 am   #4
HamishBoxer
Thank you David and Freya, I do have the RTV circuit but nothing extra. Will have another look at it.
Reply
