Old 21st Aug 2007, 10:45 am   #1
DrZarkov
Default VHF Band I or III modulator?
for my old (continental) TV-sets I would like to have a VHF modulator to connect directly modern picture sources like a DVD-player or a sat-receiver. If such devices have a built in modulator, it's allways UHF. Of course I have a UHF to VHF converter, but I think it would make more sence to connect it directly to the TV.
Does such a converter exist? Input should be composite video/audio.
DrZarkov is offline
Old 21st Aug 2007, 10:09 pm   #2
Andy Green
Default Re: VHF Band I or III modulator?
Try Polytron - they do cable and SMATV equipment
www.polytron.de
Andy Green is offline
Old 21st Aug 2007, 10:20 pm   #3
stuie319
stuie319's Avatar
Hi there,
The Aurora will do it. Theres a dip switch on board for using the unit in passthrough mode as a modulator only.
Its perhaps not the most economical way if you just want a modulator, but at least its tried tested and stable, plus you get the convertor thrown in
Regards,
Stu
stuie319 is offline
Old 22nd Aug 2007, 2:09 am   #4
arjoll
arjoll's Avatar
Jaycar do one for Australian channels 0 and 1 in band I:
http://www.jaycarelectronics.co.uk/p....asp?ID=LM3872
Note the stereo version will probably be A2 stereo not NICAM.
arjoll is offline
Old 22nd Aug 2007, 7:06 am   #5
DrZarkov
The Australian modulator is very cheap, sounds interesting! I have to look in how far it will be compatible to the German system. I've got a good tip from Oldeurope per PM, he's advising me the cable converter Axing AVM1-02, the cheapest I found until now is about 50 EUR. That's the top end I wanted to spend for a theoretical simple device. The Aurora will not work for me, our VHF system is unlike the British system basically the same as on UHF. The only remaining TV transmitter in my area is indeed ARD on CH 9 from Langenberg near Cologne, the rest is now digital only.
DrZarkov is offline
Old 22nd Aug 2007, 8:46 am   #6
arjoll
arjoll's Avatar
The Australians (and NZ) use system B on VHF, the only difference being the channel frequencies and stereo system - NZ uses NICAM, Australia uses A2.
arjoll is offline
Old 22nd Aug 2007, 10:49 am   #7
DrZarkov
The German band I is from 48.5 MHz up to 67.something MHz, with tolerances of old TV sets it would be no problem. I didn't found where the Australian channels 0 and 1 are. I hope it will match with our CH2 or 3?
DrZarkov is offline
Old 22nd Aug 2007, 11:30 am   #8
arjoll
arjoll's Avatar
AU channel 0 is 46.25 vision, 51.75 sound; channel 1 is 57.25 vision, 62.75 sound so you shouldn't have a problem switching it to channel 1.
As a comparison NZ channel 1 is 45.25/50.75, channel 2 is 55.25/60.75 and channel 3 is 62.25/67.75. Kat is sucessfully using a NZ ch2/3 modulator I sent over last year to run some European TVs - https://www.vintage-radio.net/forum/...ad.php?t=13219.
Unfortunately I haven't gotten my hands on any more dead VCRs with VHF modulators since I sent hers over, and she's got first call on the next couple anyway
arjoll is offline
Old 22nd Aug 2007, 4:20 pm   #9
DrZarkov
I've just ordered 2 of them, I think the price in unbeatable.
DrZarkov is offline
