Reply
Old 6th Sep 2022, 12:42 pm   #2881
Philips210
Default Re: The Audiophoolery Thread.
I suppose PVA would be suitable?
Regards,
Symon
Philips210 is offline   Reply With Quote
Old 6th Sep 2022, 2:41 pm   #2882
emeritus
Don't forget that there are different types of PVA. The type used for gluing wood can be slightly acidic. I acquired a 5 gallon drum of industrial PVA from the infant school where my wife was a governor after a H&S inspection condemned it as unsuitable for children's use. But the true audiophool would no doubt prefer to use the PVA-type glue, EVA, that I use in bookbinding. It is employed where archival permanence is required because it has neutral pH and so will not damage paper. A plus for the audiophool is that it is somewhat more expensive than PVA!
emeritus is offline   Reply With Quote
Old 6th Sep 2022, 3:29 pm   #2883
Craig Sawyers
Craig Sawyers's Avatar
Yes, I have heard of the PVA glue trick before. You would need to be a braver person than me to try it though!
Craig
Doomed for a certain term to walk the night
Craig Sawyers is offline   Reply With Quote
Old 6th Sep 2022, 8:15 pm   #2884
DonaldStott
DonaldStott's Avatar
Agreed - think Ill just stick with my RCM (apologies for the pun!)
BVWS Member
DonaldStott is offline   Reply With Quote
Old 6th Sep 2022, 10:12 pm   #2885
joebog1
WE could always use one of our unwanted punk albums Craig ?.
Joe
joebog1 is offline   Reply With Quote
Old 6th Sep 2022, 10:40 pm   #2886
Craig Sawyers
Sounds like the most appropriate fate for a punk album
Old 6th Sep 2022, 11:01 pm   #2887
fetteler
fetteler's Avatar
Can I be serious for a moment?
If any of you good folks here do actually have any unwanted punk albums then please let me know and I will very happily take them off your hands.
Steve.
Those who lack imagination cannot imagine what is lacking...
fetteler is offline   Reply With Quote
Old 6th Sep 2022, 11:09 pm   #2888
wd40addict
wd40addict's Avatar
https://highend-electronics.com/prod...cy-transformer
wd40addict is offline   Reply With Quote
Old 6th Sep 2022, 11:51 pm   #2889
joebog1
Already gave them away fetteler. Apart from heavy opera, the only other music I DONT listen to is punk.
Joe
Old 7th Sep 2022, 12:11 am   #2890
Radio Wrangler
Radio Wrangler's Avatar
If cleaning punk albums, shouldn't a little green dye be added to the PVA?
Old 7th Sep 2022, 3:27 am   #2891
joebog1
Only for eye rish punk!!.
Engrish punk should be red.
Scottish, blue as you should know.
Joe < runs and hides
Old 7th Sep 2022, 8:56 am   #2892
RichardGM
Techmoan recently tried very hard to be fair to the phools: https://www.youtube.com/watch?v=f-QxLAxwxkM
RichardGM is offline   Reply With Quote
Old 7th Sep 2022, 10:08 am   #2893
Radio Wrangler
I wonder how 36 degrees was arrived at?
Maybe what they need is a non-isotropic plastic to make CDs from, so that light travels only vertically and has significant loss horizontally. Hmmm, new presto wonder solution. Dip your CD in it, and then apply a strong mag field to orient the new non-isotropic property... special mag field machine sold separately at extortionate price. Drops only need to be distilled water plus a little alcohol and detergent. A spot of a suitably mysterious colourant might help sales.
Pseudoscience-R-us
Old 7th Sep 2022, 10:13 am   #2894
Craig Sawyers
Originally Posted by wd40addict View Post
Almost makes you wistful for the sort of crazy stuff that Peter Belt (RIP) used to purvey. https://pwbelectronics.co.uk/wp-cont...aper-Clips.pdf
At least Belt actually seemed to believe in his stuff. Before his strange and weird accessories activities, he was a noted designer of professional audio power amplifiers.
There is even an active groups.io set up by believers in Belt's products https://groups.io/g/PWB
Craig
Old 7th Sep 2022, 12:32 pm   #2895
stevehertz
stevehertz's Avatar
Craig
If Belt was, as you say, a noted designer of pro audio power amps I find it hard to believe that he believed (in the sense that they worked) in his audiophoolery products. Unless he foresaw the emerging audiophoolery market and/or thought that it was a better, easier way to earn money. Or, he could have just done it for private laughs. Who knows.
stevehertz is offline   Reply With Quote
Old 7th Sep 2022, 7:32 pm   #2896
Buzby123
Buzby123's Avatar
Well, I've just spent an hour looking at posts in the PWB group.
Improve the sound of your CD by freezing it, then slowly returning it to room temperature. ( A 15 to 20% improvement apparently, YMMV )
Put a QR code in you wallet if you want HiFi sound from your Walkman.
Set your clocks 99 minutes forward, this improves the sound no end.
Simplest of all, make sure all your toilet seats are closed !.
I'm still trying to work out what planet these people are on.
Buzby123 is offline   Reply With Quote
Old 8th Sep 2022, 9:00 am   #2897
jjl
jjl's Avatar
Originally Posted by Radio Wrangler View Post
Fully correctable, certainly.
But this is the audiophoolery thread, so we must consider the effect of knowing that there were errors on a British Standard audiophool.
While they seem happy to contemplate huge expenditure on mains cables, the concept of buying a CD player with a (pre-correction) error rate display is only going to cause distress, and the emission of a lot of unhappy adjectives.
Everyone knows that there is a difference in sound between a corrected sample of precisely the same value and arriving at precisely the same time as an uncorrected, unmolested sample straight from the disc. Don't they?
John
jjl is offline   Reply With Quote
Old 8th Sep 2022, 9:11 am   #2898
Craig Sawyers
There was an article in WW or HiFi News back sometime in the 70's about using two toilets as horn loudspeakers.
The author called them loohorns.
Better not close the lid in that application!
Craig
Old 8th Sep 2022, 11:30 am   #2899
Radio Wrangler
Some degree of protection from confused people might be a good idea.
Old 8th Sep 2022, 11:42 am   #2900
Craig Sawyers
Belt used to advocated filing notches on mains plug pins. There was some sort of rule to do with even number and odd number of notches on different edges of a pin. Like someone said, maybe Belt was just having a laugh.
Surprisingly something that does improve the sound is to get rid of anything high Q and resonant, like crystal ornaments etc. You can find this by standing in the middle of the room and clapping, then listening for an extended piiinnng, or a cacophony of different frequency pings. I ousted them all to a cabinet in another room. Now that did improve the sound quality, but in this case for good physical reasons. I even got away with that one with SWMBO.
I however did not get away with acoustic damping panels. Even though you can get them printed with images of your choice, so they just look like (rather thick) pictures on the wall. Just could not swing that one at all. Over my dead body was the general gist.
Craig
Reply
