Old 7th Aug 2023, 4:16 pm   #1
Christian79
Default Panasonic AG-MD830 blinking "d" in Display
Hello,
I have a Panasonic AG-MD830 that shows a flashing d in the display. I recently bought this unit and have never used it myself. According to the service manual, it is the indication that there is dew in the unit. Since the unit has been in a room with a constant 22 degrees Celsius for almost a week before it was switched on for the first time, I do not assume that the dew is real.
Does anyone have any experience with this?
Many greetings from Berlin Germany
Christian79 is offline
Old 7th Aug 2023, 5:48 pm   #2
its ur aerial
its ur aerial's Avatar
Default Re: Panasonic AG-MD830 blinking "d" in Display
Very little experience with commercial VCR`s personally, but if you can locate the dew sensor, I would try blowing some hot air on it from a hair dryer, this was the method used on domestic equipment years ago.
Ken G6HZG.
Life is not Hollywood, life is Cricklewood.
its ur aerial is offline
Old 7th Aug 2023, 8:41 pm   #3
ben
ben's Avatar
Ripple on the psu secondaries can cause unusual faults.
Ben.
ben is offline
Old 8th Aug 2023, 7:14 am   #4
Christian79
Ken G6HZG.
Hi and thank you for your message. I already had the same thought and have also tried this, unfortunately without success. I am also not sure where exactly this sensor should be located. According to my research, it should be on the main board, but I have not been able to identify it.
Old 8th Aug 2023, 12:43 pm   #5
Amtec123
On Pro Panasonic machines the dew sensor was usually attached to the head drum assembly just below the tape path. Look for a couple of thin normally white wires going to a small patch.
It's alright leaving me.
Amtec123 is offline
Old 8th Aug 2023, 6:47 pm   #6
Maarten
In early (consumer) machines it was sometimes off to the side of the tape path. A ceramic or similar patch with two wires soldered on to it.
I don't think it was ever mounted on the mainboard as that didn't have enough thermal mass.
Maarten is offline
Old 8th Aug 2023, 7:26 pm   #7
wave solder
wave solder's Avatar
They often looked quite similar to this:-
wave solder is online now
Old 8th Aug 2023, 7:47 pm   #8
Red to black
Red to black's Avatar
oddly enough if you suspect the dew sensor you can short it out to prove the point, counterintuitively when dry they are a much lower resistance, one would think they would read lower when damp!
Red to black is offline
Old 8th Aug 2023, 8:27 pm   #9
HamishBoxer
HamishBoxer's Avatar
Check/change all power supply secondary caps.
HamishBoxer is online now
Copyright ©2002 - 2024, Paul Stenning.
