Reply
Old 7th Jan 2019, 1:28 pm   #1
M3VUV51
Default Op Amp test jig.
Hi all, does anyone know of plans for a DIY Op Amp test jig? A sort of go/no go tester. I have a few to check.
Regards M3VUV 73.
M3VUV51 is offline   Reply With Quote
Old 7th Jan 2019, 1:33 pm   #2
Ted Kendall
Default Re: op amp test jig
One of those little Chinese chip testers you can get on auction sites would do the job.
Ted Kendall is offline   Reply With Quote
Old 7th Jan 2019, 1:37 pm   #3
Terry_VK5TM
Elektor Electonics did a diy jig in March 2005 page 74.
Pretty sure most of the electronics mags have done one at some time in the past.
Terry VK5TM
https://www.vk5tm.com/
Terry_VK5TM is offline   Reply With Quote
Old 7th Jan 2019, 2:37 pm   #4
David G4EBT
David G4EBT's Avatar
I built a simple op-amp tester many years ago which I've just dug out of a drawer. I was horrified when I opened it up, to find that it was way back in 1995 when I built it! I was even more horrified to see that I must have knocked it up in a hurry on a piece of scrap vero-board, mounted in a tatty ABS box, with a Dymo label on it. But it works and I guess that's what matters most. Functional if nothing else. Heaven knows how long the battery has been in it.
Inside the box is a wonky label which states that it was from a Babani Book - 'All about Op-Amps' otherwise I'd have had no clue as to where the circuit was from. I've found the book and scanned the article, which I've appended below. Not much to say about it really. I've since built a 555 tester and both work on the same principle - plug in the IC under test, press the momentary push button and if the IC is good, the two LEDs flash at intervals. I guess that nowadays, I'd be tempted to add an output socket to see the waveform on the 'scope, but maybe that's a step too far.
Hope that helps a bit.
Name:	Op Amp Tester Circuit Only.jpg
ID:	176072   Click image for larger version
Name:	Op Amp Tester Text.jpg
ID:	176073   Click image for larger version
Name:	Op Amp tester box.jpg
ID:	176074   Click image for larger version
Name:	Op Amp Tester inside the box..jpg
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is online now   Reply With Quote
Old 7th Jan 2019, 4:12 pm   #5
julie_m
Default Re: Op Amp test jig.
That's using rather a lot of parts just to do something so simple!
I'd have used the op-amp itself as the oscillator, and then all the test box really need contain apart from the battery and "test" switch is a handful of passives. Bonus points if you replicate the circuit another three times and use two 8-pin and one 14-pin chip sockets, so you can test an entire 324 in one go -- or a 5534 and a 5532 simultaneously!
julie_m is offline   Reply With Quote
Old 7th Jan 2019, 4:45 pm   #6
M3VUV51
Spot on, cheers all.
Old 7th Jan 2019, 4:59 pm   #7
merlinmaxwell
merlinmaxwell's Avatar
An elegant solution, maybe a slow oscillator with a buffered LED to show the rising and falling waveform.
Cats have staff, it's dogs that have owners.
merlinmaxwell is offline   Reply With Quote
Old 7th Jan 2019, 5:01 pm   #8
Philips210
Hi.
You could also mount the 555 timer IC and socket on the front of the box to check these as another option.
Regards
Symon.
Philips210 is offline   Reply With Quote
Old 7th Jan 2019, 6:01 pm   #9
David G4EBT
Originally Posted by Philips210 View Post
Hi.
Regards
Symon.
True enough. I made a separate 555 tester back in 2015 as I'd been given a lot of 555s of unknown provenance.
Just four resistors, two caps, two diodes and a push button.
As it happened, all the ICs were good when tested. It's a long time since I built anything on strip-board so I designed a little PCB for it, but for anyone not so inclined, it's so simple that it could be made on perfboard and not boxed up. I spaced the PCB on pillars below the front panel and used a little 'tower' of IC sockets pushed together, with the top one fixed to the front panel with epoxy. (The PCB artwork in pic 3 is shown 'flipped' so could be used for the laser printer 'iron on' technique).
Not directly relevant to this thread, but it might be of interest.
Name:	555 Tester Circuit.jpg
ID:	176093   Click image for larger version
Name:	555 Tester PCB Component side_edited-1.jpg
ID:	176094   Click image for larger version
Name:	555 Tester PCB Flipped Horizontal.jpg
ID:	176095   Click image for larger version
Name:	IC socket tower.jpg
ID:	176096   Click image for larger version
David.
BVWS Member.
Old 7th Jan 2019, 7:20 pm   #10
Philips210
Hi.
That's another useful project in a professionally made box. When I build a 555 tester, I might add a pot to alter the frequency and have some test points to connect to the oscilloscope. I like the idea of the stacked IC sockets, they look like the better quality turned pin type.
Regards
Symon.
Old 9th Jan 2019, 11:13 pm   #11
calicobramble
Back in the day RS offered little test pcb's for 741's and 555's. I don't have the part numbers to hand, but they are obsolete anyway. I have however seen the same sort of thing advertised on ebay.
I've used these to check if the centipedes in my bit box are still alive. For the 741 just inject a signal and see if it comes out OK on a scope; for a 555 you just need the scope,
Best rgds Simon
calicobramble is offline   Reply With Quote
Old 16th Jan 2019, 10:50 pm   #12
Jimbo
I bought a small 'Raaco' cabinet with plastic drawers full of components from one of the Yeovil 'QRP' amateur radio sales, -probably from a 'Silent Key' clear out I expect.
Included in one of the drawers were packets of the RS pcbs noted by Calicobramble above: Stock no. 434-071 for the 555 Timer board and 434-065 for the 741 Operational Amplifier. Component placings other than the IC itself are noted as R [or C] suffix 'a', 'b' or 'c' so the user would select absolute values to suit the required application.
Another drawer contained examples of RS Stock number 305-478, 'Integrated Circuit Timer', aka the 555 to go with the pcbs, [although the DIL package itself is just labelled "RS Timer A". Each component was in an individual cardboard box and with a
printed data sheet giving formulae to calculate the 'R' and 'C' values for use with Monostable or Astable applications.
How times have changed!
Jimbo is offline   Reply With Quote
Reply
Copyright ©2002 - 2019, Paul Stenning.
