Old 16th Sep 2021, 2:18 pm   #1
Northyorks1
Default Ear Radio-Packagram service sheet
I have just bought this model, but can only seem to find a one page schematic. Does anyone know of a more detailed service manual. Upon opening it is not very obvious how chassis is removed. I bought it as record player working but radio not, I notice it has the AF117 transistors, using all my skills and expertise I gave them a tap and a poke and radio sprung in to life. With my expertise now all used up, I am now stumped on how to remove chassis. I bought this model because it was in very good cosmetic condition, but on taking base panel off to access batteries I have found that the base panel is badly damaged due to damp, not mentioned when bought! Any tips on how to delicately remove material from panel without damaging it.
Ian
ID:	241429   Click image for larger version
ID:	241430   Click image for larger version
ID:	241431   Click image for larger version
Northyorks1 is offline
Old 16th Sep 2021, 5:44 pm   #2
AC/HL
AC/HL's Avatar
Default Re: Ear Radio-Packagram service sheet
Just a guess, but that mix of batteries may be the reason for the apparent damp damage. It's a recipe for disaster. The Kodaks at least may well be reverse polarised in that stack.
AC/HL is offline
Old 16th Sep 2021, 6:14 pm   #3
paulsherwin
paulsherwin's Avatar
Given their track record, I wouldn't rule out the Duracells
You should be able to fabricate a new bottom panel from hardboard or thin plywood.
paulsherwin is offline
Old 16th Sep 2021, 8:29 pm   #4
Northyorks1
Good point Bill, batteries were in player when opened, so don't know how long they have been there. Yes Paul I am planning to replace the board, just wary of damaging the material.
Ian
Old 17th Sep 2021, 8:54 am   #5
Edward Huggins
It's not "dampness" as you might know it - just battery leakage. I would not replace the origignal base at all, but just give it 2 coats of Wood Hardener. Check for corrosion around the battery terminals as well.
Edward.
Edward Huggins is offline
Old 17th Sep 2021, 1:54 pm   #6
Northyorks1
Thanks for advice Edward, on closer inspection the leakage has penetrated all the way through the board to the material on the other side, and is just crumbling when touched as it is still very damp. Probably only option is to replace the board, problem being removing material without damaging it. Checked the terminals and one is corroded.
Ian
