Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval. |
18th May 2016, 9:43 am | #1 |
Use of the Vintage Radio Service Data DVD-ROM
I have had a copy of this DVD for a number of years now and the CD based version that preceded it. It is one the most useful resources, if not the most useful resourse, supporting my interest in vintage radio.
I bought it, of course, to give me access to service information on my collection of 100 or so sets, but its value goes beyond its usefulness as a service aid. I often look at sets for sale on line, in particular on eBay, not usually with a view to purchase (I have enough sets already) but just to see what is out there. If I see something unusual or something that interests me for some other reason, there is a very good chance there is information on it on the ROM. The other use I get from it is in my attempts to help other forum members with problems with their sets. Having access to so many circuits makes it so much easier to help. I suspect many of you out there get much more than expected out of this wonderful resource, true? |
18th May 2016, 9:53 am | #2 |
Re: Use of the Vintage Radio Service Data DVD-ROM
I agree.
I have the original CDs (including the later update one), but the data has been copied to my PCs for easy access and safekeeping. If data proves hard to pinpoint, I find that searching for it using the online index accessed via the ad at the top right of each forum page often helps point me to the right PDF. N. |
18th May 2016, 10:08 am | #3 |
I must admit I don't know what I did before I bought mine well actually I do remember I searched through a very full 4 drawer filing Cabinet though original and becoming more flimsy by the day service info
It's excellent value for money. Having scanned service data myself I know just how much work scanning that lot in was! Cheers Mike T
18th May 2016, 10:14 am | #4 |
Hi Nick,
If you copy the index, along with the data, to your hard drive you should be able to find the right pdf very easily. |
18th May 2016, 10:16 am | #5 |
Thanks for the tip, Colin, I will look into that.
ISTR running into problems though because I just bought the update CD rather than started afresh with the full, new DVD. I bought the CDs just before I joined the forum, so I must have had the use of this excellent resource for over 11 years now. How time flies! N. P.S. Is there much on the BVWS Trader Sheet disc that's not on Paul's disc? |
18th May 2016, 10:23 am | #6 |
When I started really getting interested in this I found it incredibly useful. Someone would write on the forum, for example, 'Yes, it's a bottom end coupled aerial circuit' or what have you and I'd wonder what that actually meant. Referring to the service information on the DVD for the specific set mentioned and then comparing it to other sets made things clear particularly in conjunction with Miller/Spreadburys Radio Circuits Step-By-Step book(s).
Even if uninvolved in the discussion, I like following any serious faultfinding of sets via the relevant service sheets as I nearly always learn something. Super resource and I genuinely feel the money on both this and the valve DVD was well spent. Andrew
18th May 2016, 1:18 pm | #7 | ||
Administrator
Right now the long process of sorting and scanning is ongoing (Mike Barker has loaned me several large boxes full of data). I am still hoping to have it/them available towards the end of this year but it depends on work and other priorities. For those who copy the data to the hard disk the new disks are being structured so it can all be copied into one folder structure (so no conflicting filenames) and an overall index PDF file will also be available. The new disks will also work with recent editions of Adobe Reader, and the existing disk will get a new index.pdf file at that point too (which will also be available to download). |
19th May 2016, 7:13 pm | #8 |
The DVD is really good, I will want the new ones when available, a wealth of knowledge in them.
Frank |
