21st Nov 2015, 12:10 pm | #1 |
Beocord 5500 B & O cass deck schematic/advice please
Beocord 5500 B & O cass deck schematic/advise please
UNITS TYPE NO - 4932 hi all, this unit is cursed with an int issue on occasion,when play,fast forward,or rewind selected,deck starts,then stops a few secs later,with pinch roller/head assembly remaining engaged from this point,if any of the functions selected again,the same happens.only difference the second time is that the units tray motor also spins anyone with experience on these units ? |
21st Nov 2015, 1:41 pm | #2 |
Re: Beocord 5500 B & O cass deck schematic/advise please
i observed the fault could be instigated at a faster rate,on occasion,by selecting auto reverse
even though the reels were turning before unit faulted,on removal and inspection of idler,i noticed a distinct and clear gap between idler gear & the gear on motor spindle also noticed idler plate had become warped over time,hence the 2 gears moving away from each other through the process of heating,the bending,i managed straighten plate,back to it's original shape,then froze it in place also cleaned/lubricated idler & reels not sure this has cured issue,but will report back after testing |
23rd Nov 2015, 12:31 pm | #3 |
Re: Beocord 5500 B & O cass deck schematic/advice please
this one has failed again
possibly reel sensor issue ? |
3rd Dec 2015, 11:41 am | #4 |
cleaned grease from back of both capstan flywheels,that contact with back plate,then re - greased.
this seemed to improve matters slightly,but would still stop next,i replaced capstan belt,with one of less tension.now plays without stopping. i suspect there's weakness,within the capstan motor,therefore will quite possibly replace that also |
3rd Dec 2015, 12:21 pm | #5 |
That type of motor are known for being faulty in other B&O equipment. Good motors but the bearings fail after 30+ years.
John. |
3rd Dec 2015, 3:26 pm | #6 |
hi John,yes suspect you are spot on,cheers
just to prove the point,i replaced capstan motor,and also fitted back the original belt,which has more tension.seems to be playing ok at the moment. will update once fully tested |
