Old 28th May 2009, 7:08 pm   #1
MALC SCOTT
MALC SCOTT's Avatar
Default Grundig Party Boy 500 Poor FM.
Hi, i have just been given this radio from a forum member. It works perfect on AM but very poor reception on FM. I have cleaned the wavechange switches, but no better.
Malc Scott
MALC SCOTT is offline
Old 28th May 2009, 7:53 pm   #2
repairman 1234
Default Re: Grundig Party Boy 500 Poor FM.
Hi Malc,
This looks like a nice little radio, hope you can sort the FM problem
I suppose this will be one of those sit down for a couple of hours with the door shut and a cup of coffee jobs
Good luck,
repairman 1234 is offline
Old 28th May 2009, 8:47 pm   #3
Steve_P
Steve_P's Avatar
The service sheet is up top there. Check that the aerial is connected There are 2 coils and a cap that connect the aerial to the set. Check these.
Cheers,
Steve P.
Steve_P is offline
Old 28th May 2009, 9:28 pm   #4
yesnaby
yesnaby's Avatar
Hello,
I have one of these. Works great on AM/FM (touch wood!)
Michael
yesnaby is offline
Old 29th May 2009, 7:47 am   #5
davidw
davidw's Avatar
FM IF alignment? Any sign of disturbed cores in the 10.7Mhz path?
Dave G1AGK.
My perception is my reality!
davidw is offline
Old 29th May 2009, 10:10 am   #6
Paul Stenning
Administrator
Paul Stenning's Avatar
Originally Posted by yesnaby View Post
Hello,
Michael
I have one too and can confirm that the FM is really good when they are working properly. So it is definitely faulty and not poor design. They were released in about 1974 and we had a few at the boarding school I went to as a teenager which is why I was keen to get another one.
I can't help with any definitive suggestions for the fault though. Check the aerial is connected OK (it uses a metal bracket that is soldered to the PCB), check for signs of the alignment being disturbed, and check for cracks in the circuit board in particular near the mountings and aerial. Then cast a suspicious eye over any electrolytics that are only used for FM.
Paul Stenning
Forum Admin/Owner and BVWS Webmaster
Paul Stenning is offline
Old 29th May 2009, 7:54 pm   #7
MALC SCOTT
MALC SCOTT's Avatar
Hi, many thanks for the replies. I will download the circuit let you know of any repair updates. Cheers, Malc.
Malc Scott
